Probably good advice mate.
what are Midland Alan 121 CB radios like?
Help
- VideoPirate
Thats what I thought. I presume a good old Box Like a Saphire or Rotel 240, York863, Nato 2000 Etc are these golden oldies better than most of the newer radios that are available today?
I'm Going to get in touch with Colin at begining of week regarding getting the Saphire repaired. I hope it can come back to life. as long as the Cost and postage really dont out weigh buying a new radio.
I may still buy a new Radio just for the car. Out of the newer style CB's what do you recomend? Mainly around about the Mid price brackett?
Thanks again Have a nice weekend
- VideoPirate
Picking up the new coax 2moz. Got my hand's on an SWR from an old breaker. Just one other Querry if someone can help out. I have a Silver not but not the Hi gain one(Mines the one without the 3 radials). Anyway I have it bolted on to the side of my garden shed at the bottom of the garden. Does the silver rod have to be earthed? Would it be better mounted on a Pole?
Cheers.
VP 8)
Cheers.
VP 8)
- VideoPirate
Well all I can say I'm Peaved OFF!! I have spent all my day of trying to get this set up working to no avail. Think I will just chuck the towel in. I put in New UR67 heavy duty coax, new PL259 plugs. Connected everything up (Used a brand new midland rig) and nothing. I always thought it was cable problem but it has to be something else. The problem is that I can recieve hardly anything. My friend tried to help me and we have tried the radios in his car with magmount and they all work fine. For example we could copy truckers on the Bypass several miles away when in the car, but when connected to the silver rod they were right at the back of the box. The SWR seems fine. One local breaker who is about 1/2 mile away only hits me with a 5 on the meter I hit him with a 3 pound signal strength. When we try in the car we blast each others windows out. Maybe a fault with the silver rod?? who knows!!! Just dont want to spend any more money and also it's becoming very frustrating. Something is pulling my receive signal away and I cant figure it out. Silver Rod is situated at the bottom of my garden bolted to my shed. I have nothing blocking my signal, The only thing os I can think off is I'm quite near an old telephone pole. (Not sure if that could cause problem?)
Well that will be me probably going 10-7 again (shame really)
- VideoPirate
Yesterday the SWR on Average was just under 2. A bit higher on some channels a bit lower on others. Tried the SWR again today and now both needles aint moving. i'm pretty sure The Silver Rod is fully extended or dam near it! Getting frustrated.
On a different topic I'm studying for my CCNA and Class A subnetting is far more enjoyable than getting my homebase set up! LOL
5/8 silver rod are poor to swr should have got a half wave
better still get a antron 99
just an idea
its all in the mast not the rig!!!!!!
just an idea
- VideoPirate
I may try a new antenna. Need to get a few more more Green sheilds first. If that doesnt work I'm going to take a hammer to the lot!!!
But seriously I want to get to the route of the problem.
i had a pc that got the wrong side of me
so i smashed it up in a mad frenzy attack
made me feel a lot better
but cost me in the pocket
- VideoPirate
Going to take another look at the set up hopefully over the weekend. I've just got to figure out what is causing the Attenuation and pulling the signal away. I'm just going to have to go back to basics and try some trouble shooting. Just a pity there aint something like the 7 Layer OSI model but designed around Radio communication.
I'll the Hammer in the tool box for the time being
I have that feeling about PC's almost on a daily basisi had a pc that got the wrong side of me
if both needles are not moveing suggests that the set is not transmitting try using the swr without the antenna plugged in and you should get needle swing if not could be the output trannie on the set this could also deafen the set
- VideoPirate
When you refer to the set are you meaning the SWR meter or The Radio?
