WHAT AERIAL
Round Baler
Here in Scotland almost every truck has a SIRIO ML-145 magmount or a magmount with a 5ft springer!
I sometimes work for a local Agricultural Contractor. I have a 5ft springer on a wing-mirror mount on the '06 plate John Deere 6920s tractor that I use when working for him!
- Gordon
- Gordon
Round Baler
extremedave
i have a sirio ml-145 on my tractor and its a great aerial! is it true most scotish cb's use big amps like 100w's or more round baler??
Round Baler
Dave: Most of the tractor operators that I know who have CB's fitted also use a 100 watt burner because they are so far out in the countryside.
Since most tractor operators also have a burner then they can communicate to each other over a wide range!
Any pics of your setup including tractor Dave?
- Gordon
- Gordon
Round Baler
extremedave
is it possible to post pictures baler? and how do u do it? thanks
Round Baler
Round Baler
Round Baler
I got some pics from Dave today so here yous go!
I will try and get some close-up pics of the antenna from him.
I like how you have wired a plug socket into the tractor! What does that power?
Have you got the plug socket powering from crocodile clips on the battery?
- Gordon
- Gordon
Round Baler
extremedave
thanks for posting the pictures Gordon,the socket is for powering the additive pump for when i am chopping grass with a forage harvester but i also use the to plug in my amp and the cb is wired straight from the battery using co-ax as a power lead because i was told this cut out some interfearance although im not too sure it makes much difference
Round Baler
Thanks for the info!
We made a small device consisting of a lightbulb and switch for our silage additive. When the bulb is on then the silage additive is on.
It powers straight from the battery!
- Gordon
- Gordon
Round Baler
