High SWR reading
Brando
CB Handle: Mosquito
Just checked My SWR reading on my set-up in the car and it's REF reading was right over into the red at the SET part of the meter (like when you're setting the SWR meter up at FWD).I use a mag mount placed in the middle of my roof.Is it likely to be a broken SWR meter or patch lead?Oh, the mag mount i use is pre-swered.
Guzzy
CB Handle: Guzzy
Most likely the coax.
Jon
check the meter is the right way round and read it very carefully if a slight differance on ch 1 and 40 then alter antenna if nhigher on 40 shorten antenna
cheers and beers b :D
