hi
im 15 and i was recently given a JESAN CB-950 well thats what it says on it as you may be able to tell i have no clue at all but id like to start using it can any one give me any tips on it how it works the range it would have i was told 3 miles im just looking for some pointers really.
NEWBIE a little help
get a cb antenna from our sponsers if you go home base then the higher the better and you should reach 10-15 miles or even more on a good day even with a mag mount on the car you should be able to do about 7-10 miles with a little bit of hight
you will be ok to use it with the built in antenna
go on channel 19
and ask 1-9 for a roger
if someone says roger breaker back to you then people can hear you
if you would like to talk to someone
ask 1-9 for a copy
if someone wants a copy they will tell you which channel to use or you tell them which channel to go to
but you will get very limited range with a hand held don't expect big things
best thing would be to head to high ground so your signal gets out more
hope this helps
have a play and see what happens
ask 1-9 for a copy
hope this helps
okay thanks i will try that i had been a little nervous to try saying anything lol.
what kind of range should i excpect with a hand held one?
also would it work in the car?
thanks for being so patient every one i have no clue at all.
I would think your range would be about a mile, maybe two on a good day, talking on the CB is no worse than putting your first post on a forum, nobody knows who you are, or where you are.
Avoid meeting anyone yet, unless with someone, same common sense as the internet really.
Enjoy.
Enjoy.
It's all about the MONEY
