antenna @ cable
the messiah
hi... im relivly new to CB, i.e. i got my first rig (bought from thunderpole) on wednesday,
i am running it as a hombase radio, as i cannot drive, and i am using a orbitor antenna with a magnetic, that came with the starter pack that i bought.
i am looking for a hombase antenna and have been looking at ANTRON 99 but i am not sure really what i am looking for, also can n e one help my on the types of coaxal cable i need...
my rig is: Intek-M 790 Plus And Orbitor antenna
thanx :oops:
THE MESSIAH-------2H5SG-------
antron is a good antenna get the cable from colin at thunderpole and mount as high as possable on a chimney if you can if its over tv antenna you should no cause interferrance but col will give you advice if you ask him (requests written on the back of £50 notes get preferental treatment)
hope this helps
the messiah
lol... thas gr8 thanx :D
EarthWormJim
Deffinately go for the antron 99 if you got the money thats what my father inlaw has on an adjustable mast in the back garden its fantastic and all we are running on the bottom is an old midland 2001 pushin 4 watts out the back and we get out as good if not better than those running burners. Hope this helps 8)
Jim,
2H4OW
M3OJP
trik
The coax you will need is 50ohm cable.Usually it can be found on CB retailers web sites,such as Thunderpole,or on electronics suppliers sites such as maplins.Alternatively try one of the radio ham shop sites.
Generally something such as RG58 is a good all round bet.There are others,lowwloss and such,but they get expensive,and you may not get any benefit unless you have a long run between the aerial and the rig.
HTH cheers,
trik
