Wilson 1000
- jdo330
- Official CB Nut
For all of you that have the above antenna, how easy was it to SWR (assuming its mag mounted in the centre of the roof like the one in the Peogeot in the forum gallery). I heard that the Sirio's are pretty much spot on out of the packet, kinda hoping its the same for the Wilson as I want one
Photoguy2910
- Official CB Nut
Mine was simple, stuck it on, found the centre of the whip that was in the coil and just adjusted it, ended up being about 1/4" above the deepest it can go... sitting at 1.2
108TM999
it says in the book put the antenna in by inch and the swr should be spot on
so i did this with mine and checked the swr and it was on 0 on channel 20 on the superstar swr meter
no adjustment needed you cant get any better than that can you
this is the first time iv never had to mess around with swr on an antenna
wilson 1000 is the
wilson 1000 is the
Considering my Wilson 1000 was second hand and I didn't quite know what to expect when it came to SWR'ing it, I was amazed that it was spot on.
No trouble at all & no adjustments to make !
>> 26-Tango Mike-129 : http://www.tangomike.net
>> 26-Foxtrot Bravo-132 : http://www.foxtrotbravo.co.uk
