Have i got a problem ?
POKO
Have replaced my front bumper recently with a Alloy Winch Bumper the Antenna is mounted on this.
Decided to treat myself to a Voyager Antenna, Connected up a SWR meter and the readings were very low.
40 = 1.2 / 1 = 1.0 and i have not adjusted the Antenna. :?
If i lift the bonnet then the readings rise to around 1.5
Have i got a problem or is this right as i don't want to damage the CB (Midland 48 plus)
POKO
1996 Mitsubishi Pajero
no problem as you dont drive with the bonnet open
:D :D :D :D :D :D :D :D
hotmetal1000
No you don't have a problem. Having the bonnet raised would reflect some of your rf back down the antenna. When I have my base antenna in it's upright position I have a swr of 1.3 at the most, when I lay it down parallel with the shed roof for what ever reason the swr jumps of the end of the scale.
A swr of 1.5 won't hurt your radio anyway either.
POKO
Thanks for the advice mate just i read somewhere that a low swr could cause problems and not to use the cb
It is actually the opposite. A low SWR is what you want..
A HIGH SWR can cause problems.
POKO
Just slightly worried as the needle hardly moves in fact pretty much no movement at all on ch1
hotmetal1000
Your swr is excellant buddy, many people go to great lenghts to try and achieve a swr of 1.1
do the lottery this week with luck like that
Nugsport
CB Handle: Nugsport/Steve Alli-monster
Excellent thats super SWR :D good work mate, i wish i had an SWR reading of such kind :) im one of those peep's out there at moment going to great lengths with a 9ft Tank whip to try and get the SWR reading low lol im sure i will get there.
Steve
DX The World
"Check Your Band Plan"
Homebase - Magnum S-9 Nitro Export > Sirio 827
Mobile - Midland Alan 78 Plus Multi > Sirio Megwatt 4000
26 PW 353
