Wilson Little Wil
Photoguy2910
stampman wrote:always stick the swr meter on a new antenna golden rule
Thats good advice, I always would anyway, wouldn't want to pop my rig
Photoguy2910
OK, my Wilson Little Wil arrived this morning, stuck it on my car (Mondeo) and SWR'ed it... can't get it below 5 on the UK channels and on mid it goes between 1.7 and 5...
... Any ideas what I should do?????
108TM999
boyscout
I take it you are using a mag mount? Mondeo, that has a metal roof so you should be ok for a good earth there. Not trying to insult you or trying to make you suck eggs, but make sure the SWR meter is connected up the right way round. Try the reading with another known good SWR meter.
The antenna is new, but do check for cable damage and that the antenna is securely fixed to the mount.
hope this helps, :!:
Photoguy2910
boyscout wrote:I take it you are using a mag mount? Mondeo, that has a metal roof so you should be ok for a good earth there. Not trying to insult you or trying to make you suck eggs, but make sure the SWR meter is connected up the right way round. Try the reading with another known good SWR meter.
Yup, the Mondeo has a metal roof, so that should be ok... only got the one SWR meter, might have a look for another one though... The mount loods like the antenna is moulded to it, so that should be ok too, will have a look at the cable too...
Will check it all and let you know how it goes,
108TM999
USE channel 1 mid band and 40 uk then trim the antenna by about 1/4 of an inch a time and it should come down
Photoguy2910
Well, thats it much better but 2 1/2 inches shorter, at least I know my new bolt cutters work ;)
Thanks for the advice guys :D
108TM999
