Page 2 of 2
Re: Homebase is up and running.
Posted: Tue Apr 01, 2008 9:00 pm
by Apbuild
Jon,
At the moment I have the springer on the tank. The coax is one length, down into my office with a DV elbow at the bottom of the antenna and a pl259 into the back of the rig/power. The coax is a lead from Thunderpole and is 10 metres in length. Obviously, I had to fit the DV end myself at home which was pretty easy if you have a steady hand and a soldering iron.
The so239 I have coming should accept the DV socket.
I will get a rig check from a fellow breaker I know in Oxford with the springer, then run up into the loft and change to the Wilson, swr in the office and then get a follow up rig check from the same breaker. Distance of this contact is around 12 miles.
Will report on the findings later.
Rob.
Posted: Wed Apr 02, 2008 9:31 am
Posted: Wed Apr 02, 2008 7:47 pm
by Apbuild
Here are the results from the Swedish jury....................
Got a signal check this evening from a breaker in Abingdon, Oxon. That's ten miles from me. I had left the springer in the loft and the report was that I was giving 4 pounds of signal with significant background noise. (I seem to pick up a fair bit of interference in the evening. I guess it's all the people at home with appliances and tv's running etc).
I then popped up into the loft and fitted the Wilson 1000 to the tank. See piccy below.
SWR in the office once I had climbed down was 1:1.5. That's fine with me!
The second report from my fellow breaker (he had kindly agreed to stay on channel and wait for me to change over), was that I was giving 6 pounds of signal with significant reduction in background noise.
REMEMBER THIS WAS TESTED WITH THE SAME RIG SET UP AT THE SAME POWER!
The results are plain to see. I would however like to get the 1/2 wave or even an antron back up on the chimnney. I have been advised to tape off the ends of the mounting pole to stop that 'Blow over the Bottle-top' hum that you can get in the wind.
Hope you enjoyed the little xperiment as much as I have.
Cheers,
Rob.
10-10
Posted: Wed Apr 02, 2008 8:14 pm
by jason
very good ,
from now on we shall call it ''rob's law''
the best mobile in the loft is as good as a budget homebase on the chimney 8)
Posted: Wed Apr 02, 2008 10:09 pm
by Apbuild
jason wrote:very good ,
Jason,
I still think that for long distance and clarity, you cannot beat the Antron 99, and for a tenner cheaper than the Wilson, I will be investing in one soon methinks.
It will be chimney mounted with the mount pole ends sealed up to erradicate the wind howl that I experienced before with the 1/2 wave installation.
I will report on the performance once installed and up and running.
Rob.
Posted: Thu Apr 03, 2008 8:49 am
Posted: Thu Apr 03, 2008 4:22 pm
by jason
i have an antron and the tape over the ends of the pipe is a good idea that i will use ,, i never thought of doing it but seems very practical,,
Posted: Thu Apr 03, 2008 4:42 pm
