Page 2 of 3
Posted: Tue Sep 11, 2007 9:25 pm
Posted: Wed Sep 12, 2007 6:28 am
by stevie_a
thanks you are some man
Posted: Wed Sep 12, 2007 6:42 am
Posted: Wed Sep 12, 2007 10:24 pm
by stevie_a
HELP !!!
Ok I have been out to the car tonight
Swr at 4 /4.5
Cut a wee but about 4 / 5 mm swr the same
Cut another bit off 4 / 5 mm swr jumped up to 8
Moved the rods about got swr down to 5 / 5.5
What am I doing wrong?
Posted: Tue Sep 18, 2007 8:12 pm
Posted: Wed Sep 19, 2007 5:12 pm
by stevie_a
I take it you want to see my antenna
Posted: Wed Sep 19, 2007 11:24 pm
by gaspipe58
Posted: Thu Sep 20, 2007 5:37 pm
by fatfinger
put that mag mount in the bin you will never get the swr down there crap
i had 1 after lots of cuting got it down to 3
did you get it of ebay like i did
learn the hard way and spend the most money on the mast, thats the bit that matters the most
Posted: Thu Sep 20, 2007 8:52 pm
by stevie_a
YES I DID...
I don't want anything big..
Posted: Thu Sep 20, 2007 10:28 pm
by fatfinger
thats not what i have been told
nice rotel 220
i have 1 of them
Posted: Fri Sep 21, 2007 6:41 am
Posted: Fri Sep 21, 2007 7:26 am
by stevie_a
I take it you are talking about a Wilson Littlt Wil at £29.99 what size is the Diameter of the base i can see the hight is .95mm
Posted: Fri Sep 21, 2007 10:23 am
Posted: Fri Sep 28, 2007 2:51 pm
by boyscout
Yes Steve you do. I would say that when I cut down my antenna I do only cut off about 3mm at a time, yes it can be a pain and takes longer, but I think it pays off in the end. As said before, if you rush and cut to much off then you have gone past the point off no return. One other thing is next time you are trying to find out where the interference is coming from remember it can enter in two ways, through the antenna or through the power line. I think I'm right in saying if you fit a dummy load to the rig and the interference is still being heard, then the interference is coming in through the power line. I would add a ferrite ring to the power lead. Hope my 2 bit helps
Posted: Fri Sep 28, 2007 2:59 pm
by boyscout
fatfinger wrote:put that mag mount in the bin you will never get the swr down there crap
Funny thing that, I have a Siro ML-145 on a mag mount and the SWR on Ch 40 is 1.3 and Ch 1 is just below 1.2
I don't think that you can right one thing off and say it's bad as there are so many variables to take into account. i.e. Make and type off antenna, good grounding and where antenna is situated, just to name a few
One thing I have learned is that it's mostly down to trial and error. and as you said spend the cash on a good antenna, you may have the best rig in the world, but if your sporting a cheap naff antenna there is not much going to go off at the business end.
