Hi Signal reading
Posted: Tue Oct 02, 2007 9:31 pm
Hi all
I have a problem with a high signal meter reading on my homebase. I have a York JCB 863 and an Antron99 on a 10' pole. With a EP-815 Power Supply Unit.(you can take a look at my setup if you look at the thread mount and pole The meter is always reading just under 5 all the time,(It does go up if I get a good contact.) Im sure this is not normal as in the car it is usually sits around the 2 marker) I popped into thunderpole today and asked for some advice and bought a Bandit power noise filter.
I have fitted a ferrit to the power line to the PSU and a Bandit power noise filter to the line from the PSU to the York. This has had no effect to the signal meter reading. In fact the PSU did not like the Bandit as when power was taken off from the PSU the warning light came on and started to fade after about 5 secounds(and yes it was wireed up correctly) The only other thing I could think it might be is the hight of the Antron99. Although if you take a look at the pictures I think that it's high enough and away from the roof enough not to give me to much trouble. Any ideas?????
