Page 1 of 3
Help
Posted: Thu Oct 04, 2007 10:49 pm
by VideoPirate
Hi
I have just out up a 5/8 silver rod running about 10 metres of coax. My problem is that I cant seem to pick up anything at all. I have tried 3 different rigs and problem is the same. Briefly I picked up some girl on the breaking channel when I jiggled the cable but then she was gone. I'm pretty sure all all connections are fine and have double checked. Any users have any idea what may be causing the problem. (I live in a large city with plenty aeriels around and close to the city bypass. so i think i should be picking up some cb traffic)
Thanks for any assistance you can provide.
PS I'm a newbie to this forum but was a regular CB user fro around 1982 to 1990 and have been 10-7 unti digging out old equipment. The Silver rod is brand new purchased from thunderpole and all the rigs fire up ok. Really i'm dying to get back on, also my 15 year old lad is showing some interest.
Posted: Fri Oct 05, 2007 9:00 am
basics check swr reading and make sure the cb is on uk frequancys
:D :D :D :D :D
Posted: Sat Oct 06, 2007 11:19 am
by VideoPirate
I'm still puzzled cant get anything to work. I presume I must have a broken antenna (although aerial is less than 2 weeks old)or the coax is defective. Tested cb in a friends car and they are ok.
Just another quick querry if anyone can help. I have a 5/8 silver rod. Just so i can check that i'm doing things right can some one explain the correct way to put up silver rod. I have it bolted to my shed at the bottom of the garden. (also does the rod have to be fully extended?)
Posted: Sun Oct 07, 2007 6:46 am
yes fully exted the antenna i think there are marks on the tubes to show how far they fix into each other get or borrow a swr meter as it is the only way you will get the antenna right
Posted: Sun Oct 07, 2007 12:40 pm
by VideoPirate
Thanks for your help. I think it will be back to basics. Seems to mee that the problem must be a connectivity issue. Going to replace coaxial cable mid week and see if that sorts out the problem.
Must be a mid life crissis as i'm dying to get back on the airwaves.
Another Querry. I live in Edinburgh Does anyone know of any CB suppliers Or Rig Doctors in or around my location?
Posted: Sun Oct 07, 2007 10:39 pm
sorry thats a question for andy start at basics and make sure you have no shorts on the cable plugs for starters
Posted: Mon Oct 08, 2007 11:27 am
by billy bear
like stampman was asking have you put a swr meater on the set up to tune it in. :?:
Posted: Mon Oct 08, 2007 7:19 pm
by VideoPirate
Need to get myself a swr meter. Thought I had one but seem's to have got mislaid over the years.[/b]
swr
Posted: Mon Oct 08, 2007 9:06 pm
by billy bear
ok mate good luck them siver rods are at most times easy to swr if you have forgot how to swr your setup put how to swr a cb radio in to google iam sure you can get it theres.Laters.
Posted: Mon Oct 08, 2007 9:31 pm
only way to sort it remember high on 40 shorten the antenna just use channels 1 and 40 to check the swr
Posted: Mon Oct 08, 2007 9:50 pm
by fatfinger
very good tip that stampman
=D>
Posted: Thu Oct 11, 2007 9:02 pm
by VideoPirate
Have had a Little Sucsess. I noticed about 2 meters of the coax was damaged. I cut the cable and things have improved. I'm now able to TX and RX. although I think I may be having trouble on the RX side. I have had a good few copies at least 10 miles from my location. Hiting a good 9+ on their signal meters. but even some local copies are coming in quite weak. 5 on the meter when they are less than a mile away.
I still haven't got a SWR yet so I'm not if that could be the problem. I'm still open to any suggestions or ideas that can help me out as I'm gettin a bit frustratred. To top that off My Mint Condition Sapphire X4000 seems to have died on me. It lits up and seems to work but may be a dry solder issue??? but who knows! loved that box had it since the early 1980's. I'm just left with an old Commtron CB40F which isnt the best. (I still have also a commtron VIII but its no use on the UK40 as its off frequency)
I still dont know of any CB suppliers or Rig Doctors in Edinburgh. Do Thunderpole do any CB repairs?
Thanks again
VP :evil:
Posted: Fri Oct 12, 2007 6:47 am
yes andy does repairs ring colin to sort out and it sounds like the antenna is ok if you are getting 9 miles with a good report
Posted: Fri Oct 12, 2007 11:19 am
by VideoPirate
Will Give Colin a ring At the begining of the week. I would like to get the Saphire X4000 fixed if possible & a reasonable cost. It was good box and served me well through the years. Used it a lot as a homebase and in the car for foxhunting (Hide & Seek) back in the day!
I still think My problem lies with the coaxial Cable. will Change it next week and try that. Also looking for a cheap SWR of Ebay but will wait till all the postal strike nonsense is over.
I'm enjoying this it's all like an all new learning curve all over again. (not quite as much fun as it was back in the day!)
This is a great forum by the way. Not much stuff out there. Very informative.
Posted: Fri Oct 12, 2007 1:35 pm
be carefull of 2nd hand swr meters for the cost of a new one from colin you could get it sent when the rig is returned
:D :D :D :D :D :D :D :D
