10 meter radios
Posted: Wed Oct 31, 2007 9:40 pm
by landyloon
what are 10 meter radios and can anyone use them?
Posted: Wed Oct 31, 2007 9:44 pm
10 meter radios are supposed to be fore radio hams not cb and are a little bit harder to drive try getting to grips with 80 channels before getting discouraged try to use one then it will make it simpler to opperate when you get one
Posted: Thu Nov 01, 2007 7:55 pm
by landyloon
just interested to see what are the rules for these radios like if you need licence and is transmit power more than normal cb can they be used in a motor car or truck why would you choose one over normal cb i no these question may seem silly to all you cb men but iam new to cb
Posted: Thu Nov 01, 2007 8:08 pm
yup licence needed or they will be confascated by offcom and they transmitt on more modes than ordinary cb
10 meter
Posted: Thu Nov 01, 2007 10:44 pm
by extremedave
most 10 meter radios can be easily converted to run on the 11 meter band which includes the uk cb channels,legally you should have a licence but i'd almost put my house on it to say that you won't get any trouble for using one,offcom have better things to do.
Also these radios have SSB and at certain times of year you can tranmit 100's of miles on ssb when the skip is running
Posted: Fri Nov 02, 2007 12:49 am
by Guzzy
Legally, these radio can only be used on 10m with an Amateur Radio licence.
If you convert them to operate on 11m (which is normally a very simple internal modification) they are still illegal to use on 11m even if you are a HAM.
This doesn't stop people (CBers) from doing it though. You would have to be very unlucky (or sloppy) to get caught by Ofcom.
Posted: Sat Nov 10, 2007 7:33 am
by Bodger
I used a Magnum 257 for a while, good fun but I have gone back to a normal (tweaked) CB... :)
Posted: Sat Nov 10, 2007 8:14 pm
by EarthWormJim
you'll be alright on 10meters until a licensed amateure heres you and tells RSGB and they tell ofcom who eventually come and knock on the door and take your gear away Ive seen it done twice in the last 2 years that ive been a ham.
Im just sayin it does happen
Posted: Sat Nov 10, 2007 8:57 pm
by extremedave
did you make any contacts on ssb with the magnum bodger? i'm thinking about getting one
Posted: Sat Nov 10, 2007 9:23 pm
by extremedave
Also do many licensed amateures use the 10 meter band?
Posted: Sat Nov 10, 2007 9:46 pm
by EarthWormJim
yeah quite a lot and more so when the weather is right and the 10 meter band is open for dx'ing
Posted: Sat Nov 10, 2007 9:52 pm
by extremedave
but if you use a 10 meter rig on the 11 meter band do you get any hassle? also is it legal to just listen in on the 10 meter band if u don't transmit?
Posted: Sat Nov 10, 2007 10:45 pm
by EarthWormJim
no hassle that I know of some of my mates hve rigs that do both but just like to listen on 10 meters. Its not ilegal to listen
Posted: Sun Nov 11, 2007 7:37 am
by Bodger
I have just sold a Magnum 257, although a great radio I found it to be just a little too grand for the road.....
:P :P
