best mount.!!!
Posted: Wed Nov 14, 2007 10:33 pm
by bub
Whats the best kind of antenna mount for a lorry. I could use a mag mount an place up on roof but routing the coax would be a pain in the arse so think a mirror mount might be better but would I loose out on signal power.
P.S. I'm new to this stuff and am trying to find out which pair to buy. :!:
Posted: Thu Nov 15, 2007 6:48 am
first choice should always be sirio gutter mount as it is stright to the body and this means you have no problem with the ground and if you mount it on the rear of the waggon then it is protected by the wind deflector as well win win situation
Posted: Thu Nov 15, 2007 6:34 pm
by EarthWormJim
You could use the mag mount on the roof and put coax through the sun roof, thats if people still have the cb on the shelf at the top?
Posted: Thu Nov 15, 2007 8:06 pm
only use a mag mount if you get an expensive one the cheap ones soon rust and throw the swr out
:D :D :D :D :D
Posted: Tue Dec 04, 2007 5:36 pm
by fatfinger
wilson 1000 then lol
Posted: Tue Dec 04, 2007 8:13 pm
what is the waggon could possable give help fitting
