Baffled :-s
Posted: Sat Feb 09, 2008 4:21 pm
by DIGGER
I am baffled.
I have got my antenna 1/2 Wave thunderpole, errected on the exterier of the house, 10m coax to the radio.
I cannot seem to get the SWR below 3 :?
It's on the exterier rear wall, attached using T & K bracket kit. (from the home base starter kit)
Any Idea's what I could be doing wrong???
Posted: Sun Feb 10, 2008 8:47 am
iguess you have the bracket connected to a pole with the antenna fixed to that antenna joints put into the marks and the bottomjoint should be in about 6 and 1/2 inches
:D :D :D :D :D :D :D :D
Posted: Sun Feb 10, 2008 9:33 am
by DIGGER
correct. All the joints are at the required length.
I adjusted the bottom one all over the place with little or no change.
I will take a photo of my antenna shortly and post that
Posted: Mon Feb 11, 2008 10:00 am
could be bad earth or coax
Posted: Wed Feb 13, 2008 6:51 pm
by DIGGER
Bad earth :?:
Educate me please :?
Posted: Thu Feb 14, 2008 9:10 am
the outer of the coax is not makeing good connection to a resonable amount of meatal work
