Wilson 1000
Posted: Sat Mar 15, 2008 7:32 pm
by jdo330
For all of you that have the above antenna, how easy was it to SWR (assuming its mag mounted in the centre of the roof like the one in the Peogeot in the forum gallery). I heard that the Sirio's are pretty much spot on out of the packet, kinda hoping its the same for the Wilson as I want one
Re: Wilson 1000
Posted: Sat Mar 15, 2008 11:33 pm
by Photoguy2910
Mine was simple, stuck it on, found the centre of the whip that was in the coil and just adjusted it, ended up being about 1/4" above the deepest it can go... sitting at 1.2
Re: Wilson 1000
Posted: Sun Mar 16, 2008 4:21 pm
Re: Wilson 1000
Posted: Sun Mar 16, 2008 5:59 pm
by fatfinger
it says in the book put the antenna in by inch and the swr should be spot on
so i did this with mine and checked the swr and it was on 0 on channel 20 on the superstar swr meter
no adjustment needed you cant get any better than that can you
this is the first time iv never had to mess around with swr on an antenna
wilson 1000 is the
Re: Wilson 1000
Posted: Mon Mar 24, 2008 1:24 am
by tobyw7
Considering my Wilson 1000 was second hand and I didn't quite know what to expect when it came to SWR'ing it, I was amazed that it was spot on.
No trouble at all & no adjustments to make !
Re: Wilson 1000
Posted: Tue Jun 03, 2008 9:33 pm
by <fordkid>
would a wilson antenna be good for my tractor??? good performance??? P.S i mount it on the mudguard with a magnet, wilson 1000 or 5000??
Re: Wilson 1000
Posted: Wed Jun 04, 2008 8:47 am
Re: Wilson 1000
Posted: Wed Jun 04, 2008 6:12 pm
by <fordkid>
