Page 1 of 2
Homebase is up and running.
Posted: Sun Mar 30, 2008 11:10 am
by Apbuild
Got the homebase set up yesterday.
I took the 1/2 wave down from the chimney some time ago due to several different reasons so I thought I would experiment after reading Jason's post about mobile antennas versus homebase antennas.
I tried to mount a Thunderpole orbitor on a small piece of flat metal plate, approx 12" x 12", on the horizontal binder timber in my loft. Once connected up, it worked to a degree but the swr was a little to high for my liking.
I then noticed an old galvanised metal water tank that has been sitting in my loft since I changed it for a plastic one several years ago. It is about three foot by three foot in size. I drilled a hole in the side of it, mounted the Orbitor on it and then went back down to swr again.
Got the swr down nice and low so I hooked up all of the gear and started a call out.
I was getting out to Oxford and Abingdon with really good reports on my modulation. Thats approx 10 miles on a springer in the loft! (With a little help)! And I was receiving all of the Oxford braekers really clear!
Reason for this post:
If you are prepared to experiment and put in a little time and initiative, you can get results. If you are prepared to pay a bit more money on your gear you can get better results. I may even go to the lengths of trying my Wilson 1000 on the metal tank in the loft just to see if there is any improvement.
I am glad I didn't chuck that tank out.
Cheers,
Rob.
Power supply and radio.
Re: Homebase is up and running.
Posted: Sun Mar 30, 2008 11:28 am
by hotmetal1000
Give us a picture of the tank and antenna will ya????? :D
Posted: Sun Mar 30, 2008 12:01 pm
by Apbuild
Give me a while, I will have to get the step ladders in to get into the loft!!!!!!
Be right back.
Rob.
Posted: Sun Mar 30, 2008 12:18 pm
by Apbuild
Here you go mate!
Two piccys of the tank and springer and one of the small plate that I tried but had no joy with.
If you are going to try this, my advice is to get as big a groundplane as you can.
Rob.
Posted: Sun Mar 30, 2008 1:12 pm
by hotmetal1000
That's awesome buddy, thanks for taking the time to get a picture of it.
Posted: Sun Mar 30, 2008 1:16 pm
a little gray matter and good results well thought out now get our sponsers to sell water tanks
:D :D :D :D :D :D :D :D
Posted: Sun Mar 30, 2008 1:26 pm
by Apbuild
Rusty old ones with holes in them for ventilation?
As I run a construction firm I will be salvaging any that I may come across in the future.
Keep an eye out on **** chaps!
LOL!
Rob.
Posted: Sun Mar 30, 2008 4:31 pm
by fatfinger
must be the ballcock that gets the swr down nice and low :lol: :lol: :lol:
nice work mate
and good pixs
Posted: Sun Mar 30, 2008 5:21 pm
by jason
i was going to have a little experiment of my own ,, but you just saved me some time :D :D :D
i am going to try the sirio 4000 on the roof of my house against the a99 so i will let you all know soon , i will put a fiver down that the sirio 4000 performs as good as the a99,,
Posted: Sun Mar 30, 2008 10:17 pm
by jdo330
Hi Rob,
Great write-up Rob, very interesting indeed.
So, in terms of performance vs the silver rod. Which ones best?
ATB, Jon.
Posted: Sun Mar 30, 2008 11:04 pm
by Apbuild
Can't say at the moment mate because I didn't really try the 1/2 wave for very long.
All I will say is that the missus didn't appreciate the howl down the chimney to the living room from the 1/2 wave so I had to think of something else.
The springer seems to work well but I am now intrigued to try out a Wilson 1000 in the loft because the Wilson on my 4x4 works superb.
Maybe post results later.
10-10 mate.
Rob.
Posted: Mon Mar 31, 2008 6:08 pm
by jason
nice power supply,, i use the same , 8) 8)
you cant beat having those quick connections on the front for odd jobs
Posted: Mon Mar 31, 2008 8:59 pm
by fatfinger
would love to no the results of a wilson 1000 in a loft
might even give this one a go myself :lol:
Posted: Tue Apr 01, 2008 7:40 pm
by Apbuild
Have ordered the so239 DV mount with and will post results when fitted.
Rob.
Posted: Tue Apr 01, 2008 7:58 pm
by jdo330
Rob,
How are you connecting it all up, are you runing one long coax and putting the required connectors on the ends or have you got a join somewhere :?
Also, would love to know what you think of the performance now you have had it up there a couple of days. Itching to do the same :)
ATB, Jon.
