Just Purchased First CB...Eeeeek
Posted: Mon Mar 31, 2008 6:54 pm
I have just purchased a Team ME-4 and Mini Orbitor Mobile Antenna with Mag Mount, which I intend to install into my Freelander. I have also ordered a SWR meter for calibrating the antenna to my rig (See, I`ve been reading up on these forums).
Not quite sure whereabouts I`m going to locate the rig yet (Any suggestions would be appreciated...Photos even better)...
My plan is to use the mag mount for a bit, while I get used to the CB world out there, then perhaps progress to a more permenant aerial fixing. I have been looking at the Rear Wheel Aerial Mount for the Freelander (Ebay) and hope that I can run the cable through the same hole/grommet as the windscreen wiper feed cable and into the boot space, where I can then neatly run the cable to my rig (wherever that will be...
Is it possible to have a semi-permenant aerial fixing...i.e permenant base, but detatch aerial and store in boot etc.
Anyway, I`m impatiently waiting for posty to turn up now with my goodies...
Again, any advice, suggestions, photos of your setups would be greatly appreciated.
Hope to catch you on the airwaves....is that what we say ?
Cheers,
Mick...havent decided on a handle yet (Do we still have those too ?)
Cheers,
