Do I Need To Re-Calibrate Everytime ?
Posted: Mon Mar 31, 2008 7:08 pm
by TheJester
I understand that my aerial needs to be calibrated to my rig. But if I have a "temporary" setup...i.e Rig not fixed and aerial with mag mount. Is it necessary for me to re-calibrate the rig/aerial evertime I remove the aerial and place in boot because I`m parked in a rough area for example... Or is it ok if I place the aerial more or less where it was previously...
cheers
Re: Do I Need To Re-Calibrate Everytime ?
Posted: Mon Mar 31, 2008 8:04 pm
by Apbuild
Should be ok as long as the whip is kept tight in the mount and doesn't slide in/out
Rob
Posted: Mon Mar 31, 2008 8:48 pm
by fatfinger
i always remove my wilson magmount when not in use
and the swr always stays the same
so you will be ok
Posted: Tue Apr 01, 2008 7:49 am
by TheJester
Phew, thats a relief.....
Posted: Tue Apr 01, 2008 8:35 am
