Fitting Of CB Into Freelander Completed (Photos)
Posted: Wed Apr 09, 2008 9:01 pm
The installation of my first ever CB into my Freelander, is finally complete and I have to say I`m quite chuffed with it.
I have installed the rig in such a way that it looks neat (I`m fussy like that), all the wires are concealed and most importantly, when the time comes, it can all be removed from the vehicle at any time, without any hassle or unsightly holes...
So, lets have a closer look (If you`re interested of course)...
(1) I have run a 12v feed from the Aux 12v Socket, which is located in the armrest console, using Scotch Block Connectors. I went for this 12v socket rather than the one in the dash console, simply because it was easier to get to (believe it or not)...
(2) I then ran the cable under the central console, behind the steering column and up through the hole which is located under the little rubber mat to the right of the main speedometer etc. console. This was a bit fiddley, but several grazed knuckles later and a bad back from contorting myself under the dashboard, I got there (And worth the effort)...
(3) With the Orbitor Antenna positioned on the roof using a mag mount, the coax was fed in through the tailgate window, then hidden behind the roof lining rubber strips, all the way to the dash on the drivers side. The coax was then fed up through the same hole as the 12v supply (Again quite fiddley)...
(4) Both cables were then neatly run round the back of the main speedometer dash console to the CB Bracket area...
(Note: The bracket was made from a mahogony offcut and a couple of brass angle brackets, sprayed with black Plasticote to match the dash)
(5) The connector for the 12v supply (Which allows me to disconnect the CB) was then concealed in the rubber mat which fits to the left of the main speedometer console. A short piece of flexi conduit was used to tidy up the 12v cables here...
(6) The coax is also run through this rubber mat then placed in position next to the bracket...
(7) Everything now in position, the rubber mat which came from the central armrest, was used to fill the gap next to the rig, making a usefull little storage tray for keys, fuses, phone etc...
(8) The other little rubber mat was also re-fitted to neatly conceal the cables next to the dash...
(9) And there you have it, install complete...
All the cable, connectors, flexi conduit and spare fuses cost me a grand total of £1.80
I have also made up a lead with a 12v cigarette plug and connector for attatching to the rig if I ever need to remove it from my vehicle and fit temporarly in another vehicle, caravan etc.
And this is my Mobile Unit with Orbitor fitted to roof...
And for anybody who asks "Why havent you placed the mag mount in the centre of the roof"... There are some really annoying ridges on the roof, that hinder the smooth placing of the mag mount...
Hope you enjoyed my little DIY journey and if it helps anybody else trying to install their CB into a Freelander... GREAT !
