Does a CB need a permanent power supply to hold memory?
Posted: Fri Apr 11, 2008 11:17 am
by ozzie1989
I plan to install a switch to turn my TTI-TCB 880 on and off. As it is placed in a cubby box, I fear that at some point I will leave it on, hence the switch with warning light on the dash. Will the 880 keep it's memory set stations even if it doesn't have a permanant power supply?
Thanks.
Re: Does a CB need a permanent power supply to hold memory?
Posted: Fri Apr 11, 2008 12:33 pm
i think it will lose them if you remove the power supply
:D :D :D :D :D
