Burners
Posted: Wed May 14, 2008 3:01 pm
by nato 2000
Heyy all im kinda new to your forum and i love it and had a question about burners for you, i just bought a RM KL200 and was wondering if burners pull in aswell as push out signal and do i have to buy anything else so run it at full power or is my power pack (13.8v) ok to do this and is this a good burner? p.s i will be running this on a nato 2000 in the house and on a communicators in the car (will i need anything to run it in my car aswell or just a patch lead)
and answers will be greatly appreiciated. cheers guys
scott
Re: Burners
Posted: Thu May 15, 2008 8:20 am
the kl200 has a preamp built in which should drag the signals in but make sure you dont put more than 5 watt into it from the rig and either use a car battery or a power supply that will give you about 15-20 amps plus the antenna has to be lower than 1.5
Re: Burners
Posted: Fri May 16, 2008 7:47 pm
by nato 2000
ok thanks alot stampman i should have the amp tommorow aswell as my new astatic road devil mic :D i cant wait to try them out.
have you had any experiences with that mic?
many thanks for repling to me.
scott.
stampman wrote:the kl200 has a preamp built in which should drag the signals in but make sure you dont put more than 5 watt into it from the rig and either use a car battery or a power supply that will give you about 15-20 amps plus the antenna has to be lower than 1.5
Re: Burners
Posted: Sat May 17, 2008 7:41 am
the astatic mic's are a very good mic seem to make the audio on tx very clear
:D :D :D :D :D :D :D
Re: Burners
Posted: Tue May 20, 2008 10:04 pm
by fatfinger
astatic mic's are awesome
you cant go wrong buying one of them,
the rolex of mic's
