Page 1 of 2
Boomerang
Posted: Wed May 10, 2006 12:01 pm
by the spanner
Hi i was wondering if the boomberang twig is any good?
I need a twig to use at home that is not to big, and one that my parents wont get annoyed with stuck on their house, so i liked the look of the boomerang. Anyone have any ideas about this twig?
Posted: Wed May 10, 2006 12:19 pm
Hi and welcome to the forum
Basically, the Boomerang is a good twig if you cant go for anything bigger.
It wont work as well as, say a 1/2 wave but will outperform an Excalibur or a mobile antenna on a biscuit tin!
Posted: Wed May 10, 2006 1:46 pm
by the spanner
it will work better than what im using at the moment then, a tiny ickle twig on top of a celebrations tin
Posted: Wed May 10, 2006 8:25 pm
by Round Baler
Hi, I have the same problem as thespanner.
How would you mount it?
What sort of range would you get if it was on your roof?
- Gordon
Posted: Wed May 10, 2006 10:28 pm
by Round Baler
Hi....Does anyone have the height and width of the bracket that is supplied with the boomerang twig?
I was thinking about mounting it like this:-
Would I need to earth it and if so how would I do it?
Thanks,
- Gordon
Posted: Thu May 11, 2006 8:29 am
by simon007
I have here a Hurricane 27 which is a small 60cm antenna. Looks like a shrunk dipole. Had troubles with the swr initially but after mountng the antenna its working well. I have spoke to Poland and north Germany with it. Almost the same signals as with my Antron
Simon
Posted: Thu May 11, 2006 8:32 am
by Round Baler
Hi, how far are you from Poland?
Have you got a link for the antenna?
Thanks,
- Gordon
Posted: Thu May 11, 2006 8:35 am
by Round Baler
Could we possibly have some pictures of the antenna, the mountings etc...?
- Gordon
Posted: Thu May 11, 2006 12:03 pm
The mounting bracket is 35cm x 2cm.
I will take some snaps later on today and post them here...
Posted: Thu May 11, 2006 12:24 pm
by Round Baler
Thanks for the info!
It was much appreciated!
- Gordon
Posted: Fri May 12, 2006 12:59 pm
I've been outside in the beautiful sunshine and taken some pics. It was a hard job but someone had to do it
The mounting - A flat metal bar with two holes to either attach to a wall/surface with two bolts or onto a 2" pole with a u-bolt...
Hope these help...
Posted: Fri May 12, 2006 6:07 pm
by Round Baler
Thanks Andy, those do help!
I will think about it. I am going to college in September so I'm unsure weather to buy 1 just now or not as I will not be at home to use it.
I will be taking the SIRIO HYPOWER 3000 that I'm using just now and put it on my window ledge at college!
I would wonder if I could bend the bracket(where the holes are) up 90 degrees do that i could attach it to the plastic going round my house.
Do you need to earth the boomerang?
Thanks,
- Gordon
Posted: Mon May 15, 2006 12:29 pm
You should be able to bend the bracket to fit it to your house, you would probably need a big hammer or something though!
As far as earthing goes, you dont need to, but you can earth the mount if you want to. The best way is to run a wire down to an earthing spike pushed into the ground.
Posted: Mon May 15, 2006 7:29 pm
by Round Baler
Thanks Andy
- Gordon
Posted: Sun Aug 20, 2006 6:32 pm
by Round Baler
Andy: What is that antenna you were taking pics of above?
Can you send me the link please!
- Gordon
