TTi-880 & Muffeled TX Audio
Posted: Sun Aug 31, 2008 5:53 pm
by NToombes
Hi
Just fitied last weeend a TTi-880 that was purchased from Thunderpole 2 weeks ago. First time our group have been out with since ths unit was fitted and everyone else has said that the TX audio from the TTi is awful! I have had a listen and I would say its seriously over deviating! The mic gain is set midway and talking in a normal voice a few inches from the microphone. The RX signal on the TTi is lovely.
It has been suggested to me on another forum that there were a batch of TTi's with this problem but he thought these issues had long been ironed out.
Any suggestions??
Neil
Re: TTi-880 & Muffeled TX Audio
Posted: Mon Sep 01, 2008 9:03 am
try using the mic further away from your mouth
:D :D :D :D :D *King* *King* *King*
Posted: Mon Sep 01, 2008 2:14 pm
by NToombes
stampman wrote:try using the mic further away from your mouth
Hi
yeah tried that (microphone on lap whilst driving), all we get is a very quiet voice and loads of road and background noise. Even got the mic gain turned fully anti-clockwise. Just been talking to him via my radio on the way home, its basically unuseable!!
Neil
Posted: Mon Sep 01, 2008 4:06 pm
take it back to your suppliers unless andy knows a fix for it give colin a ring and ask for andy
Posted: Mon Sep 01, 2008 4:43 pm
by NToombes
stampman wrote:take it back to your suppliers unless andy knows a fix for it give colin a ring and ask for andy
Thunderpole are the suppliers!!
I have emailed them direct but will give them a call tomorrow if I dont hear back!
Neil
Posted: Mon Sep 01, 2008 4:56 pm
Hi Neil,
I did reply to your email this morning.
In case it has got lost somewhere I will resend it now.
Posted: Mon Sep 01, 2008 5:27 pm
by NToombes
andy@thunderpole.co.uk wrote:Hi Neil,
H Andy
OOh nothing in my inbox, will check Google spam filters etc and if I cant find anything give you a call tomorrow.
Neil
Posted: Tue Nov 25, 2008 9:31 pm
by slowpoke
the tti 660 also has the same problem and its nit the fact you are to close or the moulation trimer is set to high there is either a bad batch of mikes or the tx is of or the mod chip it faulty. i am going to try a new mike , as i have changed the mike insert and it has mode to difference. i
canot send mine back as i bought it on e bay and its for to much trouble its easy to get a new mok. if this fails then i will cahange the mod chip and get the tx frequenciy sorted. last resort pre amp for the mike. or put it under the rear wheels of mi 40 foor tri axle trailer fully loaded and drive over it
that cures the problem, unles any one can sugest any thing else. :evil: :cry: ::-() :lol: :D
Posted: Wed Nov 26, 2008 8:21 am
you could try a power echo KM-452 with the echo just set up on the first devision they make a big differance
Posted: Mon Mar 02, 2009 5:15 am
by daryn
Hi mate we are having the same problems with ours ,we have the tti 660 and the tx audio is terrable ,really muffled if you here anything let me know and i will do the same for you. #-o
Posted: Fri Jun 18, 2010 1:41 pm
by named4
I have the same problem as you folks too, muffled tx audio on FM. I sent it back to the manufacturer, and recived a new one, but the problem still remained.. i tried to have my broder talk int it from my car, and i was listening inside in my mocoma 59, i had a hard time her what he was saying, because of the bad sound. But the Rx audio is very good in tti 880, much better then the mocoma 59.
Have you boys tried AM? because the rx/tx sound is perfect on AM mode on mine, quite wierd.. But no one uses AM, so the problem remains..
Channel 21 fm, Finland
4
Posted: Sat Aug 14, 2010 4:39 pm
by simon007
I have a German bought 550, 770 and 880H Max and the only one that had issues was the 550. Changed the electret insert and lowered the audio trimmer and was better. The others are indeed hard on the audio, and the 880H Max that came to me was so strong could take your fillings from the teeth especially on AM. It landed in its full export glory direct and the internal speaker was bad :shock: so is now sent back to be replaced but the audio was loud and had the restriction take out i believe and now wait the maybe working version to be sent back
