SWRing of Antennas
tincahunter
Hi Folks
Would i be right in thinking if i swr my twig at ground level the reading i get will be slightly higher than when i mount it on the chimney.I am going to try get the tip above gutter level and be at least 10 feet away from the house.If you have any other suggestions i would welcome your input.The twig i am erecting is an A99 solarcom and i am hoping the swr will not go too high when i operate on my full frequency range 25.1 to 29.7.
Hopefully i will be on the air this time next week weather pending.
Mark
a99 are pre tuned so you will be ok from the word go
:D :D :D *King* *King*
tincahunter
Cheers Stampman
