ground plane
Posted: Thu Oct 30, 2008 8:58 pm
by bassy 1019
hi i want to use my sirio4000 in the garden, dont want it fixed, if i buy a groundplane to put it on would this work? or how to make one, put it on biscuit tin high swr.
Re: ground plane
Posted: Fri Oct 31, 2008 7:58 am
our sponsers do a ready made ground plane which works very well and is not over expensive which will sort yor problem out
:D :D :D :D *King* *King*
Re: ground plane
Posted: Fri Oct 31, 2008 3:37 pm
by bassy 1019
hi stampman can you point me in the right direction
Re: ground plane
Posted: Fri Oct 31, 2008 4:46 pm
:D :D *King* *King*
our sponsers do a ground plane made out of aliminium in the shope of a cross with a hole in the middle for a mount the legs of the cross will support the antenna or are you mounting it on a pole if so its a differant kettle of fish
:D :D
Re: ground plane
Posted: Sun Nov 02, 2008 11:44 am
by bassy 1019
magmounts dont stick to ally, so need some other form of metal
Re: ground plane
Posted: Mon Nov 03, 2008 8:41 am
you can take the sirio off the mag and use a so239 body mount in the center of the ground plane
Re: ground plane
Posted: Wed Jan 14, 2009 6:40 pm
by dino2k9
do any of u guys know if corregated iron is goodto use as a groundplane? :?
Re: ground plane
Posted: Wed Jan 14, 2009 10:39 pm
bit iffy as the whole of the mag will not be in contact with the tin try flattening the tin so the contact is 100 percent and you should be ok
Re: ground plane
Posted: Wed Aug 05, 2009 5:34 pm
by Red Rider
I've used to run a tornado stinger magmount on an old car wheel rim which i earthed and got a pretty good SWR of 1 - 1.5.
best thing i've ever found is a sheet of 8x6 5mm thick steel off cut from a steel fabricators (had holes drilled in the wrong places so it was going cheap as an offcut.... £20!) which i winched up onto the garage roof (HEAVY!!!) and earthed it up to a grounding rod and the swr meter doesnt even move hardly.
Re: ground plane
Posted: Thu Aug 06, 2009 8:00 am
sorted then
Re: ground plane
Posted: Thu Aug 06, 2009 11:11 am
by killer cam
:D :D
