Picking up engine noise
andyd99
CB Handle: andyd99
Fitted a different rig yesterday, swr'ed it in no probs works great until i start the engine then it picks up a load of engine noises through the external speaker. I now you can get surpressors and stuff, but what kind will i need, will the ones in halfords do the trick???????????????
try and see you cant lose anything except a bit of time and a couple of pounds
Godzilla
how olds the vehicle? modern vehicles have good noise suppression fitted cos of all the electronics gizmos fitted, it could just be rf noise the alt. or even rf from the plug leads, but modern leads again should have low rf output. until you can track down whats causing the noise you'll not solve the problem
andyd99
CB Handle: andyd99
It's a 1991 j reg shogun, have brought an alt supressor for it, will try it later.
Daedalus
Maybe you could try a ferrite bead or ferrite ring clamp placed on the CBs' power lead and external speaker wire. They can be bought for nect to nothing but You can usually pull them off old parallel Printer or monitor cables if you have any old ones lying around. Clip it on and it should help to stop RF interference, But it will depend how strong it is.
HARRIER - CBX ---quality CB built on the famous Cyberrnet 134AOX board.
'Breaker One-Nine, what's your 20? I Hammer'd Down on the A3
I eyeballed a Kojak with a Kodak so I pulled in behind a Suicide Jockey.'
the interferance is coming down the antenna so ferrite rings will not help it about .000001 percent chance of it being in the power leads so needs either suppressors on the altinator or new plug leads
