Cybernet beta 3000 cb
Posted: Tue Feb 03, 2009 7:42 pm
by andyd99
Does anyone know if the audio can be turned inside the above rig? Works great but everyone i speak to says the audio is really low. Got my swr really low to about 1.5, can pick up loads of people on loads of channels, and transmit ok, but just wondering if it can be done, does anyone know if its a big job??
Re: Cybernet beta 3000 cb
Posted: Sun Feb 08, 2009 5:03 pm
by porky.69
i wouldnt say its a big job its just finding someone to do it ?? or just have a look at a power mike wich would give you more punch with the audio
good luck with it
Posted: Mon Feb 09, 2009 9:31 am
Posted: Wed Feb 11, 2009 9:56 pm
by andyd99
Cheers guys, where would you recommend I get a echo power mic from, and whats a reasonable price to pay for one???????
Posted: Thu Feb 12, 2009 7:53 am
Posted: Wed Feb 25, 2009 5:55 pm
by Daedalus
The Cybernet Beta 3000 has no Mic Gain, The only way I see you being able to get a higher audio level is to use a power mic. The Beta 3000 I had a few years ago came with a [Non original] power mic- No bad reports from it unless I turned the mics power down. I also see a lot on ******* with power mics so maybe the audio is like this on all the Beta 3000's?
Posted: Tue Nov 02, 2010 2:34 am
by Dragonfly
Had a look in my old scrible pad and i have the beta 3000 as having a mike gain horseshoe trim pot . it was a long time ago when i worked on one so cant be certain it is correct.
This board , PTBM134AOX is also used in -
Harrier CBHQ / CBX
Binatone 5 star
Binatone Speedway
Fidelity 2000
Transcom GBX4000
York JCP 863
