NOT SURE WHAT IS WRONG
Posted: Thu Feb 26, 2009 9:31 pm
I have a Chevrolet astro van, which has a fibreglass roof, therefor no good for a mag mount. I was told that i needed a No ground aerial.
I bought a SIRIO no ground aerial, which i have mounted on the spare wheel carrier on the back door. The cable that came with the aerial was not long enough, so rather than join it, i bought a four metre cable with the connectors already on.
I have the cable going between the hinges on the back door, rather than drilling holes, the door closes so i hope this does not damage the cable.
I have been told that no ground aerials, do not need to be earthed, is this correct ?
I have got a Midland alan 48 excel multi, which i power from a cigar lighter socket. I have connected the aerial to the back of the radio, i turned it on and all i am getting is noise, i have tried all channels but am getting nothing. When i press the mic button, the signal pointer goes over just over half way, this seems excessive to me.
Also it says that this rig comes set to EC frequencies , how do i set it to UK frequencies ? Simple as possible please as i only have one arm.
Sorry this is long, i hope i have explained everything, as not very technically minded.
Any help please, would be much appreciated. thank you
