Page 1 of 3
help please
Posted: Thu Mar 26, 2009 5:51 pm
by jonny66
i had cbs years ago and then lost interest.
recently i bought a cobra 148. i want to set this up mobile on a landrover.
what aireal is the best for this rig, i will mount it through the roof
would appreciate any advice
Re: help please
Posted: Thu Mar 26, 2009 8:21 pm
the wilson 1000 or sirio 3000/4000
Re: help please
Posted: Thu Mar 26, 2009 9:00 pm
by FISH
Good choice.
Re: help please
Posted: Fri Mar 27, 2009 6:05 pm
by jonny66
thanks guys
ive checked out both on line.
is the wilson worth the extra £60 i assume as every thing you get what you pay for!!
Re: help please
Posted: Fri Mar 27, 2009 7:13 pm
by FISH
cough,cough,cough.
Re: help please
Posted: Fri Mar 27, 2009 7:29 pm
by porky.69
like stampman says for a good dx antenna sirio or wilson the best two for all bands .. :)
Re: help please
Posted: Fri Mar 27, 2009 8:52 pm
by jonny66
thanks guys
guess its pay your money take your choice time
once i get sorted will let you know how i get on
Re: help please
Posted: Fri Mar 27, 2009 9:09 pm
by FISH
I would check on diffrent forums and see if there have any reviews for these antennas first.
Re: help please
Posted: Fri Mar 27, 2009 11:22 pm
by piper spence
Hi a good twig for mobile is a simple "springer" or sometimes called "stinger's" they are very cheap very robust and perform suprizingly well,They have quite a good bandwidth to. Get one, use it, then buy a very expensive mobile antenna and you will notice only a small improvement if any. I use one regulary with a SS 3900 had no problems and get good report's. Cheep cheerfull and does the job well.
Re: help please
Posted: Sat Mar 28, 2009 10:01 am
by porky.69
MINE ONLY COVERS THE 80 CHANNELS THATS WHY I USE THE SIRIO FOR SSB WORK *King*
Re: help please
Posted: Sat Mar 28, 2009 11:47 am
by Road_Hog
jonny66 wrote:thanks guys
No, it isn't. However I think you've probably looked at the Wilson with magmount included price and the Sirio 4000 without magmount. I think it's about a £40 difference.
The Sirion 4000 & Wilson 1000 are the best mobile aerials bar a tank whip (which is not for use on the move). Generally the longer an aerial the better (up to about 9ft for a mobile aerial) and the balance is made up of a loaded coil to bring it up to 9ft electrical length. Although the coil fools the radio in to thinking it has a 9ft quarter wave aerial, the coil doesn't actually radiate any signal. The Sirio 4000 is longer than the Wilson 1000, but the Wilson claims it has some super duper special coil that is more effective than any other base loaded coil, there by making it perform better than longer aerials.
If you go looking for reviews on the web, you'll see some people say the Wilson performs better and others saying the Sirio is better. I never tested them back to back and most people will tell you the best one is the one that they've bought. One thing you can be sure of, it certainly isn't worth the extra money in terms of performance.
I have a catalogue from a CB shop from 2004. The Wilson was £49.95 inc magmount and the Sirio 4000 was £45.00 inc magmount. Nothing has changed except the price differential.
Re: help please
Posted: Sat Mar 28, 2009 5:23 pm
by killer cam
wilison 1000
Re: help please
Posted: Sat Mar 28, 2009 9:03 pm
by jonny66
aaarrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
its a mine field. #-o #-o #-o
Re: help please
Posted: Sat Mar 28, 2009 10:01 pm
by Offplanet
As Piper Spence said, the Orbitor (also known as Stinger or Springer) is a good choice for a 4x4 as it's robust and works well - used with a strong 3/8 fixed mount through the centre of the roof for maximum range.
The other antennas suggested are excellent, but the Orbitor is certainly a tidy low budget performer and there's nothing that can go wrong with it.
I have found that the shorter versions (Trucker 80) do struggle to SWR down over a larger frequency range and I've had to choose the band I use most, and tune it down to that.
Please also make sure you buy a SWR meter and patch lead to test your installation.
Re: help please
Posted: Sat Mar 28, 2009 10:12 pm
by jonny66
think my minds made up on the sirio 4000 swr meter and patch lead monday morning :D :D :D :D
then i can get chatting not typing. :lol: :lol:
cheers guys for all the help
i remember the day when i used to make dipole aireals out of a length of coax, had a twig on a car wheel on tin foil in the loft
also found my old tear drop astatic mic in the loft, will have to dust that of!!
