Page 1 of 3
Thunderpole Forum Members on the Air
Posted: Fri Jun 05, 2009 10:09 pm
by Offplanet
Hopefully a place to post when we're out and about on the air.
To kick-off - I'll be operating from Somerset on Sunday June 7th (from around 11am ) on 27.555 or nearby.
I'm also happy to put a shout out on the UK or EU bands (say channel 25?) if anyone wants to name a time/channel.
Cheers.
Gary
26-TM-2307
Re: Thunderpole Forum Members on the Air
Posted: Fri Jun 05, 2009 10:53 pm
by porky.69
hi gary if the weathers ok then il be on high ground in shropshire will listen out for you on sunday :wink:
Posted: Sun Jun 07, 2009 9:43 pm
by porky.69
well the weather was a washout last weekend was very nice ..i surpose we have had our summer now dxing from home #-o
Posted: Sun Jun 07, 2009 9:51 pm
by Offplanet
Yes, that's probably it for this summer.
Hope you can sort the QRM if you're going to operate from home.
Copied a couple of TM stations today, plus one in to Milan - so not a complete washout.
Cheers.
Posted: Sun Jun 07, 2009 9:55 pm
by porky.69
nice one gary i only get qrm when the guy next door has his tv on ..i think he got some sort of bt hubb
Posted: Sun Jun 07, 2009 10:09 pm
by Offplanet
Make friends with the guy and perhaps he'll let you in to sort it.
Have a look at the UKQRM videos link on the www.ukqrm.org site - click on the pictures and hear the sound of the QRM (might help you find out what it is). Might just be a noisy switch mode power supply in his TV, and a ferrite on the flex and TV coax might do the trick.
I got the noise down from S9 to S1 at my QTH - a cheap DVD player, two cheap CRT TV's and the power supply on a broadband router were to blame.
Cheers.
Posted: Wed Jun 10, 2009 8:03 am
by porky.69
hi gary hes not a nice guy at all my neighbours are all nosey devils .... curtain twitcers and anti cb radio :( :D
Posted: Wed Jun 10, 2009 9:01 am
by Offplanet
That's a shame.
If it's BT vision and it's BPL/PLT adaptors, you've probably had it - having said that, the PLT adaptors are usually on all the time unless the owner switches them off (these are the devices that allow the TV service to work in multiple rooms by sending the broadband signal over the mains cables, using an adaptor that plus into a wall socket, and wouldn't just come on with the TV).
It's an easy noise to identify - http://www.youtube.com/watch?v=9V4UiTXfIto
Unless UKQRM win their battle and get the things outlawed, then often the only way to sort it is to get your Ham ticket, get a legal Ham setup, and complain to Ofcom stating "Radio Spectrum Abuse" - they will investigate on an individual basis.
If it's not BT Vision, it may be worth temporarily powering your radio via a car battery to see if any of the noise is coming up the power connection - if it is, ferrites and mains filters will help.
If it's not coming through the mains, then an earth stake in the ground with an earth bond helps with QRM (seek further advice on this if your house has a PME earthing system) or moving the antenna (the problem TV I have radiates a 20 metre zone of interference in all directions).
Failing that, experiment with wire antennas as these can be less prone to QRM (and can be made directional, so can be positioned to pick up less from a particular noise source) - look at wire dipoles (vertical, horizontal and inverted "V" configurations (lots of designs available on the 'net)).
The good thing about wire antennas is that they are pretty easy to hide in trees or disguise as washing lines etc. - the problem is that, if anything other than a vertical is used, your signal will suffer in certain directions. Again, there's a lot of examples of typical radiation patterns on the 'net.
Unfortunately QRM like yours can be a swine to fix, but can usually be improved by a lot of fiddling about and trial and error.
Hope this helps.
Posted: Wed Jun 10, 2009 12:40 pm
by porky.69
thanks gary but theres been times when ive thought about giving it all in !!!! and just going mobile but HEY WHY SHOULD I LET THESE tv and bt things
spoil my hobby :wink:
Posted: Wed Jun 10, 2009 9:00 pm
by Offplanet
I nearly went 10-7 straight away when I first put the radio back on after years away - S9 of crap at the QTH and a load of engine noise in the mobile. After two weeks he QTH was sorted and after 8 months the mobile is sorted.
Don't give up mate!
This Sunday 14th I'll be on 555, or nearby, from about 11am and if anyone is around with an FM rig, I can put a shout out on UK 25 or EU 25.
If the skip is up, it's a job for me to hear any UK stations though :shock:
Posted: Wed Jun 10, 2009 9:56 pm
by porky.69
yep gary ill listen out for you on sunday ..and last time i was on the clee hill the skip was in and all i got was 30 db of 1 and 14 division lol #-o *King*
Posted: Thu Jun 11, 2009 1:51 pm
by porky.69
well a change of day i will be on top of the clee hills in shropshire on SATURDAY NOW so if anyones around 555 usb give me a shout *King*
Posted: Thu Jun 11, 2009 10:25 pm
by Offplanet
I should be about on Saturday - I'll give you a shout mate.
If it's like today, you should get some good DX in.
Gary
26-TM-2307
Posted: Fri Jun 12, 2009 6:40 am
by porky.69
yes i look forward to that *King*
Posted: Fri Jun 12, 2009 11:00 am
by disgwylfa
Looking hopeful that I might be back on the (SSB) air later today or tomorrow.
My first tests on the radio with its new Super Co-ax and Air-choke SEEM to indicate that the RFI is gone.
The rig is set-up in the conservatory at the moment and there's no RFI into the phone from there (there was interference when I had the radio there initially).
Did a radio check yesterday and got a 5/7 with a chap in Stuttgard, so I'm hugely relieved to see it still works!
Next step is to drill hole in wall for cable and reinstall in its proper home in the office upstairs . . . . Fingers crossed.
MIGHT catch you chaps tomorrow then!
