tank whip
Posted: Sat Aug 22, 2009 1:30 am
by BlackDragon
are these aerials any good, i know they have the hight but do they do the job. I bought a cheep (ish) whipy aerial from maplin, and then i bought the discovery III off thunderpole and i have been told that the whipy is better. So would it be a waste of time buying the tank whip?
thanks a lot
Karl
Re: tank whip
Posted: Sat Aug 22, 2009 11:53 am
by disgwylfa
A Tank-whip is a very, very simple antenna. It's just a nine-foot long quarter-wave steel spire. It too big to use mobile but they do perform well as static mobile or as a home-base antenna (with a suitable ground plane). The Maplin whip is pretty poor, OK for short range on the car and you don't need to worry too much about it getting vandalised or stolen, but not a good performer. The Disco III is a good "proper" mobile antenna. I doubt very much if a tank-whip would perform vastly differently to your Discovery III.
Steve ("Cherokee")
Re: tank whip
Posted: Sat Aug 22, 2009 12:33 pm
by Firetrap
I have a TankWhip antenna, once you have sorted the SWR out you wont be dissapointed!
Just make sure you have a big enough groundplane, if not use a 9ft length of coax connected to your groundplane! It worked for me! I have had loads of great contacts in europe using it with good reports!
I also bought a firestik antenna, only 4ft in height be does give outstanding performance!
With any antenna i would suggest using a groundplane radial kit too, it decreases SWR further and improves your radiation pattern.
Cheers,
Lee
Re: tank whip
Posted: Sat Aug 22, 2009 2:23 pm
by killer cam
iv never used one sorry
Re: tank whip
Posted: Sat Aug 22, 2009 8:34 pm
by porky.69
heard good things about them
Re: tank whip
Posted: Mon Aug 24, 2009 8:26 am
Re: tank whip
Posted: Mon Aug 24, 2009 12:57 pm
by porky.69
been tempted lots of times to try one but ive got the sirio silver megga watt antenna
Re: tank whip
Posted: Mon Aug 24, 2009 12:58 pm
by FISH
Re: tank whip
Posted: Mon Aug 24, 2009 2:20 pm
by disgwylfa
Yes, Ed uses a Tank-whip for static mobile if the weather's too foul for him to raise the Antron. I've had a good contact on ground wave with Ed while he's had the tank-whip up, over about 30 miles on SSB.
Re: tank whip
Posted: Mon Aug 31, 2009 4:33 pm
by porky.69
dont know but my sirio 400 kicks ass
