Page 1 of 3
oh dear its not working
Posted: Wed Aug 26, 2009 12:06 pm
by randombod
i have fitted a springer to the rear spare wheel using a wheel carrier bracket and this is connected to the rig via an extension cable to the rig an intec m110 - plus . now i have another of the same rig that when i key the mic ( the other rig is outside the car with a mag mount antenna) this registers to the rig in the car, but when some one else uses a different type of rig i cant hear them or them hear me what have i done wrong have i blown the rig? i am tempted to get a new rig is it worth it
Re: oh dear its not working
Posted: Wed Aug 26, 2009 12:25 pm
by disgwylfa
It sounds to me like your connection to the new Springer and Mount is faulty. If that "extension cable" has a dodgy connector on it it means the rig isn't reaching the aerial. You will hear your other rig, outside the car, as it is very very close and the rig would pick that up with virtually no aerial at all.
First thing to do is to check the SWR of the rig in the vehicle connected to the Springer on the wheelcarrier mount. I'd be willing to bet that the SWR is off the scale.
Fix that, and check again and (hopefully) you won't have blown the M110 in the vehicle and won't need to replace it.
Steve ("Cherokee")
Posted: Wed Aug 26, 2009 12:29 pm
by randombod
cheers for that the extension cable was a thunderpole purchase so it cant be that maybe the male to male connector and how the other plug is attached. silly question but the cast iron is painted woudl i need to remove this paint to improve the connection?
Posted: Wed Aug 26, 2009 12:44 pm
Posted: Wed Aug 26, 2009 12:52 pm
by randombod
cheers well its raining so i cant think of a better time to get wet playing with electrics
Posted: Wed Aug 26, 2009 5:03 pm
by disgwylfa
randombod wrote:the extension cable was a thunderpole purchase so it cant be that
I wouldn't say "can't be", as even Thunderpole might occasionally have a faulty bit of kit . . . say "shouldn't be" or "unlikely to be" ;)
Just check the SWR on the fitted rig... That'll at least tell you whether the problem is in that line
somewhere, rather than maybe being a problem with the rig or something else.
Steve ("Cherokee")
Posted: Wed Aug 26, 2009 8:04 pm
by killer cam
swr it
Posted: Wed Aug 26, 2009 9:27 pm
by randombod
need to purchase a swr unit...... just discovered that one of the plugs has not been soldered so it has a loose wire so it could be that but will still check it out.... cheers for the advice guys
Posted: Wed Aug 26, 2009 10:25 pm
by killer cam
get that wired and it will probs be sorted
Posted: Thu Aug 27, 2009 7:55 am
Posted: Thu Aug 27, 2009 9:23 am
by killer cam
if the co-ax is doge or isnt wired proparley the swr will go straight over 10
Posted: Thu Aug 27, 2009 10:18 pm
by randombod
you have some strange idea of fun mate
Posted: Thu Aug 27, 2009 10:33 pm
by porky.69
pl 259 sounds dodgy !!
Posted: Thu Aug 27, 2009 10:56 pm
by killer cam
thats what i throught !!!!!!!!!!!
Posted: Fri Aug 28, 2009 7:55 am
