Hello from East London !.
Posted: Tue Oct 20, 2009 10:49 am
by EddyAlpha
Hello to all,
I have just installed my new rig (Pres Johnson II), with the Orbitor, onto my Series 2A Land Rover ambulance.
That was the simple bit, however I need advice on my groundplane. The Orbitor is mounted onto a Military bumper, very large and heavy piece of steel.
I thought that would be fine, for a good low SWR reading...however when transmitting the needle is in the red...never goes below 10...
All advice appreciated, as I am not sure how to get the level down !.
Ed.
Re: Hello from East London !.
Posted: Tue Oct 20, 2009 10:58 am
Hi Ed and welcome to the forum!
I would say there was a problem somewhere, either a short or reflection from the antenna.
As you say steel should be a good groundplane, so you should be getting an SWR of at least below 2 or 3.
I would check all cables and mount for continuity. Is the the antenna mounted near any other metalwork? Don't suppose there is any chance of a photo?
Posted: Tue Oct 20, 2009 11:35 am
by The Wizard
unless you are testing the swr the needle should go up to the red !
it shows you are transmitting !
Posted: Tue Oct 20, 2009 3:31 pm
Posted: Tue Oct 20, 2009 3:36 pm
Sorry I was assuming Ed knew how to use an SWR meter
Is it in the red all the time? Or when it is switched to REF?
Posted: Tue Oct 20, 2009 4:48 pm
by EddyAlpha
Hello to all,
In the FWD setting on my K-PO SWR, I have calibrated this as the instruction sheet explains, however in the REF, I believe I need the lowest setting I can get, which I is between 1-2. However the needle always stays in the red, around 10.
I do not want to damage my brand new Johnson II, so I am after advice on the groundplane. But in the meanwhile, with the rig on, and scanning the channels, I assume no damage can occur, by simply listening in-it is just when I want to talk on the CB, with such a high reading, that damage can occur...
This may sound daft, but I am new to the world of Cb radio, and bound to get it wrong !.
Advice appreciated.
Ed. 1966 2A 109 Ambulance
Posted: Wed Oct 21, 2009 8:32 am
right roll your sleves up and lets begin
swr in line and set to fwd reading press transmitt on CHANNEL 40 and set the needle to the far right hand part of the scale where it should say SET
change the switch to ref and key the mic again and read off the value it says on the dial
repeat as above on CHANNEL 1 IF THE READING IS HIGHER ON CHANNEL 40 THAN CHANNEL 1 the cut a few mm of the top of the antenna and continue to repeat till the swr is about 1.9 on channel 19 and below 2 on channel 1 and 40
you should then be able to work the cb with no problems
good luck
Posted: Sat Oct 24, 2009 2:00 pm
by killer cam
hi & welcome
Posted: Sat Oct 24, 2009 6:32 pm
by FISH
I dude 8) 8) 8) 8)
Posted: Sun Nov 08, 2009 8:35 pm
by porky.69
hello and welcome
