Page 1 of 2
Thunderpole ATOM
Posted: Tue Oct 20, 2009 8:34 pm
by WOODY R
Hi, I still seem to be having problems with my CB setup, therefore i have decided to buy a Thunderpole ATOM antenna and a side mount body fixing, which i am hoping to fix to the back door of my van. I have the aerial mounted on the ladder at the moment without a lot of success.
What i would like to know is the ATOM aerial already SWR'D in, if not how do i do this please.
Many thanks
Re: Thunderpole ATOM
Posted: Wed Oct 21, 2009 8:11 am
by porky.69
WELL a very good antenna and i didnt swr mine and it works a treat ' for a small antenna
Posted: Wed Oct 21, 2009 8:21 am
Posted: Thu Oct 22, 2009 8:37 am
by dr pepper
A DV27AF is a veritable aerial, and is top loaded and cheap, on top of that its a piece of cake to swr, just a thumbscrew and a 'stinger' at the top, I've had one of these swr when nothing else would work.
Posted: Sat Oct 24, 2009 2:06 pm
by killer cam
good antennas i have heared
Posted: Sun Oct 25, 2009 4:17 pm
by WOODY R
I received my Atom and side mount kit on Thursday, have not been brave enough yet to go and drill the holes in my back door, to fit the side mount.
I will let you know the results of the Atom when i have the courage to drill the holes
Posted: Mon Oct 26, 2009 10:28 am
Posted: Tue Oct 27, 2009 6:37 pm
by killer cam
Posted: Tue Oct 27, 2009 11:02 pm
by dr pepper
mounting the base on the metalwork direct will give you better results, if you do stick it on the body rather than the door.
I've allways had better results when directly mounted.
Centre of the roof is the best place.
If you get a boot mount then make sure you've got a good eart.
Posted: Sat Oct 31, 2009 2:20 pm
by WOODY R
Thanks everyone for your replies, the reason i went for a side mount was, the roof of my van is fibreglass, therefore no good for the aerial mounting. I am hoping that the side mount will work, as with this i will not have any cable outside, as i have previously had to run the cable between the hinges on the door which can i suppose eventually damage the cable. I would have the same problem if i used a boot mount or door mount.
Posted: Sun Nov 01, 2009 12:04 pm
Posted: Sun Nov 01, 2009 2:02 pm
by killer cam
Posted: Sat Nov 07, 2009 4:40 pm
by WOODY R
I have had another thought about an aerial mount. Would a mag mount work, if i put it on top of my stainless steel spare wheel cover ? Also thought about using a mag mount and a swivel connector and put it either on the back door or where i have metal just below the fibreglass roof.
Any advice on these ideas please, many thanks.
Posted: Sun Nov 08, 2009 5:54 pm
by Asterix
Depending on the quality of the stainless, you may find that the mag mount won't stick to it very well,if at all. probably best to think of a more secured setup.
Posted: Mon Nov 09, 2009 7:48 am
by dr pepper
yep stainless is not ferrous and a magnet dunt stick to it, marine grade 316 is totally unmagnetic.
