here I go again
Posted: Wed Apr 14, 2010 10:31 pm
by stevie_a
After my problem with my radio I decided it was cheaper to get a new one on e-bay than send it away to get fixed
so i again got a 89 plus new unused for £40 including postage
although it is working good I just cant get the swr down
sitting up a 3 have cut the whip down by about 2" still up at 3
question : can you cut too much off the whip or can you keep cutting it to get swr down
is there somthing else i can try
Re: here I go again
Posted: Thu Apr 15, 2010 6:27 am
what is the antenna and how is it mounted
Re: here I go again
Posted: Thu Apr 15, 2010 7:07 am
by stevie_a
Sirio ML145 mag mount on the van
and
Wilson little Wil on the Triumph
Re: here I go again
Posted: Thu Apr 15, 2010 9:36 am
SIRIO SHOULD BE PRETTY CLOSE COULD BE A FAULT WITH THE MAG
little will check 1 and 40 if higher on 40 then shorten whip if higher on 1 its 2 short
sirio should not need cutting if you have already cut it then whip may be too short but use swr meter and that will guide you
Re: here I go again
Posted: Thu Apr 15, 2010 9:16 pm
by stevie_a
stampman wrote:if you have already cut it then whip may be too short but use swr meter and that will guide you
Can you buy new whips?
Re: here I go again
Posted: Fri Apr 16, 2010 8:00 am
yes ring colin and he will sort you out
