help
Posted: Sat Jul 10, 2010 8:41 pm
checked swr readings channel 1 1.2 channel 20 1.4 channel 40 2.1 aerial is in loft but cant speak or hear anyone
CB Radio, Amateur and 2-Way Radio Forum
https://www.cbradio-forum.co.uk/
set rig to uk freqencey but got nothingpadster wrote:stampman wrote:make sure you are on uk frequancys and you get a squelch noise from the set they will recieve on a piece of wire with no swr
silly question but how you know your on uk frequancys rig i got is a danita 3000
got it working but cant get out far does cb or aerial have to be earthedstampman wrote:nothing as in no sound
or nothing as in squelch noise but no voices
thanks very much for the offer cam but i moved and this place is rented and its a no go thanks for offer thoughkiller cam wrote:hi padster,
looking at your post seems your in a little bother at the moment is a out side antenna not a possibility ? iv got a sliver rod that's welcome to a new home cant remember what condition its in tho !
dv27 mateclockworkorange wrote:what antenna you running?your best bet would be either a 102"whip and a ground plane kit or a dv27 on a old metal irononing board both work VERY well
