NOT HAPPY !!!
Posted: Wed Jul 21, 2010 6:55 pm
by padster
Re: NOT HAPPY !!!
Posted: Thu Jul 22, 2010 8:39 am
Re: NOT HAPPY !!!
Posted: Thu Jul 22, 2010 9:25 am
by andy@thunderpole.co.uk
Hi Padster,
It was me who you spoke to last night, after we got cut off I did try to call back but it kept going through to answerphone.
If the Orbitor has a low SWR in your front room then it proves that the antenna is tuned in and working.
Where abouts in the loft are you putting the antenna? Is there anything near it atall? As stampman says, it could be the cable. Either that or it could be the signal reflecting off something in the loft causing the SWR to go higher. Either that or the ground plane in the loft is not sufficient. Did you try mounting the magnet on the fridge freezer like we said on the telephone?
Re: NOT HAPPY !!!
Posted: Thu Jul 22, 2010 11:14 am
by padster
andy@thunderpole.co.uk wrote:Hi Padster,
hi andy i put it in the middle of loft and it went through roof i put it on fridge and it came down i am thinking old fetting some old fridge doors for loft
and putting it in there on it
Re: NOT HAPPY !!!
Posted: Thu Jul 22, 2010 11:42 am
Yeah, definitely sounds to me like groundplane issues then.
Fridge doors should be big enough for a groundplane, however if you still have issues then connecting wires like Stampman says should give you an excellent groundplane.
Re: NOT HAPPY !!!
Posted: Thu Jul 22, 2010 1:38 pm
Re: NOT HAPPY !!!
Posted: Thu Jul 22, 2010 2:29 pm
Unfortunately sponsors don't stock an actual ground plane kit anymore but as you say normal wire will do the trick
Re: NOT HAPPY !!!
Posted: Thu Jul 22, 2010 8:04 pm
by grom
Has it occurred to you that if both aerials display a high SWR it more than likely where / how you have them mounted rather faulty aerials
Re: NOT HAPPY !!!
Posted: Thu Jul 22, 2010 8:49 pm
by padster
hi grom i was not implying the aerials are faulty i was stating that i am having issues with ground planes
Re: NOT HAPPY !!!
Posted: Thu Jul 22, 2010 9:26 pm
by padster
well i got two fridge doors put them on floor and put mag mount on it swr still in red looks like cable or poles to enlarge it
Re: NOT HAPPY !!!
Posted: Fri Jul 23, 2010 3:20 pm
