carnt get a low swr reading
Posted: Fri Aug 27, 2010 9:39 pm
by sammyt1286
hi all, im new to cbing i have just brought a (other company) setup with a metior antenna and i carnt get a swr reading below 3. it was off the scale and was getting alot of interferance, i went back to the shop but they wasnt very helpfull just made me buy more bits a new mount, cable and so on, i now have a pre made cable and this has improved the swr but only to 3. i have no resistance, a good earth what seems to happand when i go to plug the connector in to my rig i just touch the end on without pushing it in and the swr gos down to 2.1 alot better but as soon as i screw the case on to surcure it it gos back to 3 that says to me when i earth the antenna it gos high swr, i try to tell this to the blokes at (other company) but they act like they know best and dont really listen to me as i said i am new to all of this and dont understand much bout it, im hoping some1 can help me. thanks for taking your time reading this.
p.s. if i try to ajust the antenna the needle wont move and also have brought a new swr meter so thats ok
thanks again sam
Re: carnt get a low swr reading
Posted: Sat Aug 28, 2010 9:13 am
by jumpingmaster
sorry to hear that your first outing into cb radio is giving you problems, new radio and all. the company should be more help full. not selling you more stuff and not curing the problem . if thats the case i would tell them you not happy, if they wont help.. get your money back and find a decent company..hope you get sorted ,there are a lot of people out there that are helpfull..
Posted: Sat Aug 28, 2010 10:33 am
Posted: Sat Aug 28, 2010 8:44 pm
by jumpingmaster
like stampman said about a good earth is right. and mount grounded. wonder what the setup is mounted on ie: is the mount fixed to steel or alloy body, or are you using the setup on some other arrangement...
In europe you will find the irish truckers using eu mode , but on AM , which you would have to put your radio to ITALIAN mode so as to be able to enable the am Transmission. other uk drivers will be on the normal UK mode on FM
once you manage to get swr sorted, you will have no more need to keep swr meter in line..
Posted: Sat Aug 28, 2010 10:14 pm
by sammyt1286
thank you all for the advice. the mount is drilled through my cab and its a steel cab i think that it has a good earth but have seen a electronic ground plate which would sort that out dose any1 no if these work or if its worth getting one. yes i think that the shop should be more helpful i even took my lorry to them for them to have a look but they said that they dont let there staff outside to do that, the youngest bloke is really helpful he did come out but was honest that he didnt no what the problem was. as i said it seems to drop the swr if i just touch the end parts of the connector and cb unit togeeather without screwing the connector on. but thanks for the replys again all is very helpful
Posted: Sun Aug 29, 2010 10:28 am
Posted: Sun Aug 29, 2010 12:31 pm
by sammyt1286
its on a merc axor 2008 its a concrete mixer in milton keynes so i dont really get up north much but thats very kind of u to have a look, the mounting point is the front corner of the drivers side and the cb id mounted to the left of me bout a meter away was the easyest plave so i didnt have to drill into trim to mount the unit. the oringal set up when i brought the kit a friend could here me bout 7 mile away but i couldnt here him but interferance was really bad i checked the swr then which was 2.7 and thats where its all started changing bit and gettin worse its been giving a rite headache for the past week
Posted: Mon Aug 30, 2010 8:33 am
Posted: Fri Sep 10, 2010 9:09 pm
by sammyt1286
Posted: Sat Sep 11, 2010 9:40 am
