best mobile ariel
Posted: Sat Oct 23, 2010 7:58 pm
by boss
hi what is the best mobile ariel for a lorry bearing in mind that i do alot of back road driveing so will get knocked about quite abit, low trees etc
thanks
Re: best mobile ariel
Posted: Sat Oct 23, 2010 10:09 pm
by chris9
Probably the large springer/orbitor type.
I used these on the farm tractors and are good with low sheds and trees.
And not bad performance if good groundplane and mounted high.
The tall Sirios are probably the best antenna though for performance, but the best one have a solid base, so not the best on tractors.
Biggest problem these days is the lack of groundplane on modern tractors and lorries with their plastic roofs.
Makes the antenna work much less effiecient, and SWRing can be a problem.
Chris
Posted: Sun Nov 21, 2010 11:36 pm
by extremedave
the ones with 2 grub screws to hold the whip in seem a good idea and stand up to abuse better
Posted: Mon Nov 22, 2010 6:29 am
Posted: Mon Nov 22, 2010 10:15 pm
by boss
Posted: Tue Nov 23, 2010 12:03 pm
Posted: Tue Nov 23, 2010 6:21 pm
by boss
no gutter above door not sure if its the original cab
Posted: Wed Nov 24, 2010 10:06 am
