president jackson 2
Posted: Fri Nov 19, 2010 7:31 pm
by CB RADIO GEZZA
hi has anyone used one of these radios,im considering getting one and would like to know if they are worth the high price tag.any info would be much apreciated.
Re: president jackson 2
Posted: Sat Nov 20, 2010 9:06 pm
by chris9
personally... for that kinda a money I'd probably import a nice galaxy radio from the US, they look loads better to me and some have quite high power outputs.
Like the Galaxy DX95T2 50watts AM/FM and 150watts ssb £234
or maybe wait till this is released:
http://www.cbradio.nl/Maas/Maas_DX-5000 ... DX5000.htm
That's just how I feel
Chris
Posted: Sun Nov 21, 2010 7:12 pm
by simon007
CB RADIO GEZZA wrote:hi has anyone used one of these radios,im considering getting one and would like to know if they are worth the high price tag.any info would be much apreciated.
The Jackson II has many good things and also a few bad ones such as a poor output transistor that seems to pop for no reason and be aware the 5yr gurantee on these radios now exclude the out transistors. It has an excellent receive on all bands and modes and with some tuning here and there works well. The new Maas radio well have sat here the Comtex which was the other version of the same radio from Qixiang in China. Also from the box works well, not the same quality as a Uniden build but it has a very similar almost 90% same FM section as the Jackson II so sounds nice on FM.
Software programmable with windows XP and so you can make your own channels within the radios bandwidth. Mid December comes the Maas if the ship is not delayed and you can find more about the radio by typing comtex cs 1000dx into any search engine. This radio is the same as the mythical Hannover and is the same as the branded Anytone AT5555
USA imports also good if you are not stopped with the customs, and they need tuning as almost all are shipped excellent on AM and SSB but not so good on FM as they do not use it so much there.
Posted: Mon Nov 22, 2010 7:45 am
by CB RADIO GEZZA
hi simon thanks for the feed back.i have seen many of your youtube videos one in particular the jfk 2 is that better than the jackson or would i be better waiting for the maas to come out.
Posted: Mon Nov 22, 2010 9:36 am
by simon007
Thanks for the answer. I really cannot tell you. SSB is not legal in the UK so there is in effect no need for the Jackson II or the Maas :? But really if you need simply an AM/FM radio then the JFK II works well. I do not have mine anymore, now here is either the TS6M from Team or indeed the Harry III which like the whole series from President is over priced in my opinion.
With the Maas, remember whoever sells it in the UK (i do not know) you would also need the software and the data cable and windows XP for programming it, otherwise it is only 28-30mhz.
I proposed an idea that seems now to have taken to some people (dealers) The Maas has A-F settings for the bands
A UK40
B CEPT
C SPAIN
D POLISH
E GERMAN MIDS
F GERMAN LOWS
Then you sort of have a fake multi EU Radio at the same time =D> But honestly, keep the cash safe at the moment and lets wait for the MAAS and see what happens. All new radios can have issues so always best to wait a little and see what happens. I will have one of the first from Maas and it will be on the website asap. But there is a lot of stuff hidden inside the Maas that needs some mods to be activated so could be a winner indeed
Regards
Simon
Posted: Thu Dec 23, 2010 10:05 am
by CB RADIO GEZZA
hi simon i have got one of the above radios when they come in stock.thanks for your advice.cant wait for it. :D :D
Posted: Fri Dec 24, 2010 5:55 am
by simon007
Well thanks for the update. Am waiting also now for one of these and in the next weeks i will receive my prototype back and will have that on air so can see if any difference with these radios. KEY Points to Remember if i can be bold enough to tell it and not be told off.
Have the software/data cable also. Program each band, each channel as you want it with the parameters like echo, bleep, key press beep all done via the software. Remember the radio is like the biggest favourites radio or memory radio you can imagine.
EXAMPLE: You program 2778125 into the display so channel 19 and then you turn the channel it will be 27795 unless you have programmed it to be 79125 etc etc so really believe me you need spend time to sit and clearly program it before using it. Without this there are so many parameters that you will need each time to change them. You hear Australia on 28540 and you change it to show this, and unless undone the radio will always now be on this frequency :mrgreen:
So, mine is expected from some sources the radio and will have it hooked into the pc asap. Its an XP Program the software and now uses the pl2003 driver while the other ones before release i had was almost impossible to get the correct drivers.
Let us know how you get on
HAPPY CHRISTMAS
Posted: Fri Dec 24, 2010 9:43 am
by CB RADIO GEZZA
the radio is coming with the software and cable will be fun trying to program it.will keep a lookout on your usual space for the videos of it.
merry christmas.
Posted: Sat Dec 25, 2010 3:10 pm
by simon007
CB RADIO GEZZA wrote:the radio is coming with the software and cable will be fun trying to program it.will keep a lookout on your usual space for the videos of it.
merry christmas.
Merry Christmas to you also. hmm maybe you ordered then from the same people as me inside the UK.? I have some on order here and also have ordered 3 from the UK for people here who wait for it. These are Anytone and come with the software and cable where the others are coming without cables. Hope maybe before end of year it lands here but depends on couriers, snow, ebay people and how things are I guess.
Posted: Sun Aug 02, 2020 11:02 pm
by Urbanfox
A lot of these radios are now made in China. Caveat emptor.
