Weather caps for 3/8 antenna mounts, are they available?
Posted: Mon Feb 21, 2011 1:23 pm
by Eviltwin
Just curious if there are 3/8 blanking plugs available for keeping moisture out of the antenna hole when nothings fitted, for example when the antennas removed for going through a car wash etc.
Re: Weather caps for 3/8 antenna mounts, are they available?
Posted: Mon Feb 21, 2011 4:10 pm
not for the 3/8 does not realy matter as it is a blind hole
Posted: Mon Feb 21, 2011 5:28 pm
by Eviltwin
Fair enough.
Posted: Wed Feb 23, 2011 9:40 pm
by snowman
is there not a chance that if you screw a antenna in with it water filled and as you cant compress water it causing a hydraulic affect and going tight before it is home? would this not affect the swr?
Posted: Wed Feb 23, 2011 10:26 pm
by Eviltwin
that was what I was thinking
Posted: Thu Feb 24, 2011 6:34 am
not realy its not deep enough
Posted: Sun Feb 27, 2011 4:01 pm
by Bionic Budgie
Me Again...
I have some plastic caps that come on hydraulic fittings to protect the thread. They come in various sizes. I used one to cap a Sirio 3/8unf stud I used a while back, they fit fine. Free to you my friend..how many do ya want?
Budgie
Posted: Sun Feb 27, 2011 4:23 pm
by Eviltwin
Just a couple to cap off a normal 3/8 mount, if you PM me your address I'll mail you a couple of stamps
Posted: Sun Feb 27, 2011 4:45 pm
by Bionic Budgie
No worries.
Do you want a plug or cap? What diameter do you require?. I ask this because there are lots of different types. I can deliver if you want as I regularly work at RAF Wattisham. If you want to keep your location a secret (I understand if you do). I can leave them someplace.
Budgie
Posted: Mon Feb 28, 2011 7:49 am
it will be a plug std thread
Posted: Mon Feb 28, 2011 11:47 pm
by Eviltwin
Something to plug a 3/8 threaded hole
Posted: Sat Oct 08, 2011 8:19 pm
by porky.69
good idea chaps
Posted: Sat Oct 08, 2011 8:49 pm
by joe jeep
My 3/8 fitting has rusted up inside, it is probably as old as me!! So it has done quite well.
Posted: Sun Oct 09, 2011 5:53 pm
chrome coated should not have rusted
