CB Radio usage
silican chip
Hi, I am steven, I used to be on cb radio a long time ago when I was in my teens, my handle was Silican Chip, Do people still use this system and is it worth setting up a cb in my 4x4 Pajero, I have been thinking about this now for some time but would like to make sure before buying a cb and aerial.
Steven (Silican Chip)
you can only tell by fitting one
Hi and Welcome to the forum.
You could have a look on our user map and see if there are many people in your area....
http://www.thunderpole.co.uk/user-map.html
silican chip
Hi. thanks for the info, I am in the sunderland area, the map gives a good guide of how many is still using this setup, so will start looking about for a kit for the pajero, is there any hand free headset and mics available to use instead of using a normal mic ?
thanks steven
not as far as i know but stand to be corrected you could build your own set up
Eviltwin
You'll be surprised how many 4x4 owners use CB setups in their wagons. If you ever get into off roading or green laning you'll find they're a must when you go out in a group. Just make sure you add in a mini orbitor if you plan going off road.
CB's handy for getting pre-warnings of whats up ahead of unforseen things that can damage your vehicle, like big holes and rocks in the path, sheep, fallen trees and fords with high water levels.
