Stupid question, what is a burner?
Posted: Sun Mar 13, 2011 3:42 pm
by joe jeep
What is a burner?
What do they do?
Are they legal?
Is it worth getting one?
Few questions as I am not really sure. All answers will be brilliant!
Re: Stupid question, what is a burner?
Posted: Sun Mar 13, 2011 6:40 pm
by Eviltwin
What are they? Burner's a slang term for an amplifier. To put things simply, they take the legal 4w signal from your rig, and amplify it up to the rated output of of the burner. This can be anywhere from 35w to 300+w depending on the output your burners rated for. Cheap ones also have a habit of playing havoc with TV transmissions (known as TVI or TV interference) leading to a messed up picture.
Are they legal? Not unless you're a fully licensed amateur radio operator, then yes, they're legal.
Worth getting one? Depends, plenty of unlicensed CB enthusiasts bend the law and use them for a bit more range (the police wont come knocking on your door unless theres been a complaint made), but remember its no good trying to transmit with more range if everyone picking you up, cant reply as they aren't powerful enough to reply back to you. Also bear in mind your antenna needs to be up to the job, to do this your antenna needs to be rated to handle more power than your burner by up to a factor of two (for example with a 300w burner try to use something capable of up to 600w), to be safe. Burners will over swing on the power output if the sounds they are trying to send out are loud.
Finally if you're going to get one, don't buy a lower powered one (buy big!), low powered ones make next to no difference, and you can get better results from using a good quality antenna.
As burners aren't strictly legal, a lot of places selling them list them as: "Linear Amplifiers" under their ham radio equipment sections. As long as they're capable of transmitting at 27MHz then they'll do the job.
Posted: Tue Mar 15, 2011 6:16 am
by 26-TM-037
What is a burner?....A device to amplify your out going signal
What do they do?....enables you to transmit further
Are they legal?... For CB ? definitely not
Is it worth getting one?...All depends what you want from radio.....lots of if's but's and maybe's ...lol
What is your current radio set up? antenna ? radio? etc ...are you Homebased or mobile?...what bands and modes do you work AM/FM.SSB??
73 Mark
Posted: Tue Mar 15, 2011 9:24 am
"Is it worth getting one?" As Mark say's it depends on your current set up...
If you are using a cheap antenna, it would probably be wiser to invest your hard earnt money in a better antenna first.
Posted: Thu Jun 30, 2011 8:00 pm
by joe jeep
andy@thunderpole.co.uk wrote:"Is it worth getting one?" As Mark say's it depends on your current set up...
Hi andy & Mark,
I have a lake man x man 950 and team me-4 run through mini 8 and rg58 (about 8.5mtrs in total) to a mag on my garage door, with a tank whip. It's used as a homebase. the tank whip can handle 1000 watts, so???
Joseph
