Strange fault.
Posted: Tue Mar 22, 2011 10:14 pm
by The Roadie
I have a rather strange fault on my setup on my Mini. Can anyone shed some light on light on this?
Without the radio on, it works perfectly. With the radio on, the rig picks up interference from the ignition.
My setup is:
MIdland 38
7" Magmount
Stinger antenna
Stereo is:
Sony headunit
Fusion 600w 4 channel amp and 6 speakers.
The thing that puzzles me is that they aren't wired up to the same feed. The headunit uses the accessory feed and the amp uses a feed direct from the battery (switched on from the headunit). The rig gets a switched ignition feed. I think that they may use the same earth point, however I can't remember as I put it all in a couple of years ago and I have had a few beers since then :lol:
The car itself shoud be quite well supressed, its from 1994 and is wired up more like a Rover Metro (not the best example I know haha) rather than an old Mini with ballasted ignition and a supressor on the coil. I also very rarely use the FM radio as I mainly listen to music stored on a USB stick.
The only thing I can think of is that the RCA leads from the headunit to the amp run behind the CB, but there is quite a gap and the co ax and RCA's are both only 2 years old. Can I fit an inline supressor to my rig?
Its not a major issue as when I've got my rig on, I'm usually convoying or doing a treasure hunt so I don't have my stereo on anyway! I would really appreciate some help though cheers!
Re: Strange fault.
Posted: Wed Mar 23, 2011 9:43 am
by andy@thunderpole.co.uk
We do inline filters for at the bottom of this page (2nd up)... http://www.thunderpole.co.uk/cb_accessories_misc.htm
Although the first thing I would suggest is wiring your CB direct to the battery.
Re: Strange fault.
Posted: Wed Mar 23, 2011 11:34 pm
by Phil_G
I'd also suggest checking that the earthing on the amplifier is 100% bright and clear.
Re: Strange fault.
Posted: Thu Mar 24, 2011 8:13 am
agree with andy wire straight to battery
Re: Strange fault.
Posted: Fri Mar 25, 2011 12:07 am
by The Roadie
Phil_G wrote:I'd also suggest checking that the earthing on the amplifier is 100% bright and clear.
Cheers Phil, found that the crimp on the terminal where it connects to the battery had worked a bit loose. Sorted it and now I can have my stereo and my rig on!!
Re: Strange fault.
Posted: Fri Mar 25, 2011 11:09 pm
by Phil_G
Pleasure pal. Any time...
