Re: Hi Everyone...I'm new round here
Posted: Sat Apr 16, 2011 7:24 pm
by MadDog
Hi. Good to see I'm not the only one returning to the scene :)
Think its time we all started a push for a proper revival of CB. Come on guys its the 30th Birthday of legal CB in the UK, let find some ways to revive this fantastic hobby and get people interested again. Anyone got any ideas?
Posted: Sat Apr 16, 2011 8:48 pm
by WATCHKEEPER
Welcome super8, their seems to be quite a few of us old timers are getting back into CB these days, and it seems that depending on where you are, you either get muppets all the time on 19 ( must be a private channel these days) however, monitorin other channels, helps to find good contacts.
Good Luck with the hobby, and Take Care
Posted: Mon Apr 18, 2011 9:25 am
Welcome to the forum and back to CB :D
Posted: Mon Apr 18, 2011 1:47 pm
hi and welcome
Posted: Tue Apr 19, 2011 4:47 pm
by Matt C
Hi there and welcome! :D :D
Fitting a CB to a campervan (especially a coachbuilt) can be tricky, but quite frankly I can't believe they aren't more popular, they are an absolute godsend if you travel in groups. I use CB between my camper and the wifes car (when we take it) sometimes when we travel with friends who also have a van.
Second-hand CB's can be a bit hit'n'miss, but then so can new ones! My advice is to wire it straight from the leisure battery and not the vehicle battery, you get a much cleaner signal whilst on the move! Good luck with the installation mate!!
Posted: Thu Apr 21, 2011 6:05 pm
by Matt C
Very difficult to say without seeing your set up. One of the biggest killers is people trying to run their fridge off the 12volt, after they have parked. A TV running through an inverter for three hours, along with lights and the like, will kill a 85aH battery in three hours. I use two 120aH gel batteries wired in parallel with a 85watt solar panel on roof and as a failsafe, a 1000watt generator. I use a 650watt inverter. In 8 years, I've never ran out, but I've been careful not to kick the arse out of it by using microwaves or anything like that...
Posted: Thu Apr 21, 2011 6:12 pm
by Matt C
Forgot to ask, what type of camper do you have? If it is a panel-van, you've got it made!! Dead easy! If it is a coachbuilt or A class, you may struggle with high SWR, gutter-mount or not!
You can see how I ended up wiring mine if you search the 'motorhome' section on this site. It is a bit extreme, but it was the only way to get the SWR down...
Posted: Thu Apr 21, 2011 6:17 pm
by Matt C
