Can't Wait, Homebase Setup as Easter Present
Posted: Thu Apr 21, 2011 9:39 am
by joe jeep
I'm hoping to get my Homebase setup, sorted after easter. I've got a Lake Manxman, not exactly the greatest CB on the market now or then, which runs via a 5m patch lead to a 7" eco mag-mount on to an open garage door with the 9' Tank Whip. The setup is designed so that when packed away, you wouldn't know anything is there. I can't have a Homebase aerial because of my next door neighbor. Aaaaarrrggghhh, anyway I made the best of my situation with my budget. And you know what, I am so impatient, I just can't wait to get on the air and use my mobile and homebase rigs together.
WOO HOO!
Re: Can't Wait, Homebase Setup as Easter Present
Posted: Thu Apr 21, 2011 11:47 am
by joe jeep
Another thing I worked out was if i wanted to have the garage door closed, the magmount should hold on to the door even at 90 degrees then if I could find or make something that would screw in to the magmount and was about 1 foot long I could put a 3/8 swivel adapter. That would mean that I could have my aerial up with the garage door closed, the reason I would have to have the piece about 1 foot long between the mag-mount and the 3/8 swivel adapter is so my aerial wouldn't hit the overhang from the roof.
The point I'm trying to make is that I need something about a foot long that would screw into the 3/8 fitting in the magmount and would enable either an aerial or a 3/8 swivel adapter in a 3/8 fitting. In short a piece of metal or whatever that is 1 foot long with a 3/8 male at one end and a 3/8 female at the other. Please leave ideas or suggestions.
Posted: Thu Apr 21, 2011 1:06 pm
by Dragonfly
Antennas do work good on the garage door but if your garage has a flat roof like mine then u could try what i have done ,
9 ft bars laid on my garage roof make a great groundplane,A Tank Whip will work better than this Modulator im using.
Posted: Thu Apr 21, 2011 1:59 pm
by joe jeep
Looks absolutely Fantastic unfortunately my garage has a house on top of it so that wouldn't work for me. What could I make a 1 foot section to go between mt mg mount with a 3/8 male fitting and at the other end a 3/8 female fitting.Do you know what sort of metal do they make the 3/8 adapters and the 3/8 fittings you get in mounnts out of?
Posted: Thu Apr 21, 2011 3:55 pm
