window mount
Posted: Tue May 10, 2011 9:10 pm
by GlobeTrotter
Hi just wonder would a handheld antenna and window mount work on any cb radio??
By the way it isnt for a handheld cb
Like some thing on this page
http://www.thunderpole.co.uk/cb-handheld-antennas.html
Re: window mount
Posted: Wed May 11, 2011 7:47 am
Re: window mount
Posted: Wed May 11, 2011 7:10 pm
by ellitanthalas
As I understand it, the handheld antennas are for handheld radios, in that they have a BNC connector. At the least, you'd want one of the adaptors to accomodate the SO239 on whichever CB you have.
You might not get much of a range with the handheld antenna, either.
If size is the issue, I use an Atom antenna on the bike, with an EGP mount and I get a good 10 miles from that when I'm out and about.
Re: window mount
Posted: Thu May 12, 2011 4:32 pm
Re: window mount
Posted: Sun Nov 11, 2012 2:04 pm
by Dragonfly
For my Midland 42 Handheld i use a N type to SO239 adaptor , With this i can connect any Magmount Antenna combination to my handheld and get great range but the antennas do draw high power from the handhelds causing them to get hot if u are modging continually so best to switch to low power when running in convoy .
N type to SO239
If your radio has BNC connection use
this BNC to SO239
Re: window mount
Posted: Mon Nov 12, 2012 6:39 am
Re: window mount
Posted: Mon Nov 12, 2012 11:10 am
by Dragonfly
I do apollogise ,its been so long since i used it that i had forgoten that mine was the Radioshack TRC-1015 80 Channel handheld not the midland , they do look very similar but as you say the Midland 42 is BNC and it is the Radioshack / Maycom handhelds that are N type connection . The handhelds put out allmost 4 wats when used with the car adaptor as they get 13.8 volts as apposed to 12 volts from the internal batterys and this i think is why they get hot when used a lot with an external antenna .
Re: window mount
Posted: Tue May 14, 2013 11:35 pm
by wildfire
i went looking at the on glass cb antenna & by the looks of it thunderpole don`t sell them anymore so that goes that idea
Re: window mount
Posted: Wed May 15, 2013 11:43 am
Sorry Wildfire, that is discontinued now...
Re: window mount
Posted: Wed May 15, 2013 9:19 pm
by wildfire
lol andy i noticed mate thunderpole has a lot of good items discontinued.
Re: window mount
Posted: Thu May 16, 2013 8:53 am
Re: window mount
Posted: Thu May 16, 2013 9:36 pm
by wildfire
i would give up on the window mount antennas found some where where they sell them GlobeTrotter & they no good to be blunt unless you only need it for a convoy as you will only reach 3 miles if your lucky but if your driving a GlobeTrotter cab i have seen GlobeTrotters with a mag mount on the rear with some thing like a 3/8 swivel adaptor attached to it with the antenna attached to the swivel adaptor,
or you just could get a gutter mount & bang it on to the rear as many truckers do & here is a link for you to choose what any antenna you would like from small to medium or large.
Re: window mount
Posted: Mon Apr 27, 2026 6:16 pm
by Smithdoor
Most truckers I have talk too like twin 102 inch antennas. Most time 15 miles and in Midwest upto 30 miles.
A truck is great all steel need for good ground .
Dave
