Page 1 of 2
Calling All Military Vehicle Users!!
Posted: Thu Jun 02, 2011 1:33 pm
by joe jeep
I was just wondering how may of you have Military Vehicles, WW2 era, 50's, later perhaps???
My parents have a 1942 Willys MB Jeep
and a 1944 Bedford MW.
The jeep has a Cb fitted, with 12v powersupply (the jeep itself is only 6v) and it is made to e removable so it looks original when at shows, but perfect for convoys and travelling situations.
The MW is mostly wood so a bit of a prob but can still use cb once campsite is errected.
Come Military owners?!?!?!?
Re: Calling All Military Vehicle Users!!
Posted: Thu Jun 02, 2011 2:08 pm
by ellitanthalas
Not yet, but if we ever win the lottery, I have a BIG shopping list!!
Several WW2 ones will be on there, as the wife and I are in a Living History group.
We could actually use a Jeep, if you're interested?
US 1st Infantry Division, heavy weapons company - Jeep used to carry 60mm mortars, .30cal machine guns and the bazookas. You'd get to play with all the best toys!!
Posted: Thu Jun 02, 2011 2:31 pm
by Dragonfly
You could try a no ground type antenna on the Bedford MW ,they work on the fiberglass ERF trucks ok.
Ring Thunderpoll they should be able to sort you something.
Posted: Thu Jun 02, 2011 3:00 pm
build you own ground plane with a length of coax looks neat and tidy link it with a tank whip and you will be well sorted
Posted: Tue Jun 07, 2011 11:46 am
by Donga
RAF Burtonwood near Warrington has closed now. But up until the early 90s the warehouse was full of new Jeeps of that kind. When i say new they were probably 40 yrs old then but never used. Wonder to this day who got their hands on them.
Bet there was a racket going on somewhere when they demolished the base.
Posted: Tue Jun 07, 2011 12:46 pm
by ellitanthalas
Donga wrote:RAF Burtonwood near Warrington has closed now. But up until the early 90s the warehouse was full of new Jeeps of that kind. When i say new they were probably 40 yrs old then but never used. Wonder to this day who got their hands on them.
Where did you hear this?
Not doubting you, but the world of military vehicle ownership is peppered with 'barn find' stories of people who went to Northern France and met a rural bloke, who bought a barn and found inside a mint condition Jeep, still crated from the paratrooper drop (it's always the paratroopers, usually E Co, 506th, 101st), which the French bloke was selling for something like 400 Euros... :^o
Posted: Tue Jun 07, 2011 6:45 pm
by needle bender
you know what you can do with your yankie jeeps........when i win the lottery i'll get an austen champ!!!!
Posted: Thu Jun 09, 2011 10:37 am
by joe jeep
Dragonfly, this 'no ground type antenna' does that mean it doesn't require a ground plane???
Stampman, could you post some piccies of you coax ground plane or explain it to me in a bit more detail.
oh, and has anyone got a 19 set?? do you need a amateur radio lisence to operate one of those.
Posted: Thu Jun 09, 2011 1:12 pm
by Dragonfly
The Sirio GL27 kit claims to work on vehicles with no metalcab to use as a ground plane
http://www.thunderpole.co.uk/sirio-gl27.html
There is also this type of no ground mount which uses a upside down small antenna as the ground.not shure if Thunderpoll sell this type of mount.
Posted: Thu Jun 09, 2011 1:45 pm
NO PICTURES use 8ft 6" of plain coax put ring terminal that will fit the underside if a 3/8 or dv mount connect to base and run out to end of cable dont attach to anything try and keep as straight as possible and your antenna should swr ok
Posted: Thu Jun 09, 2011 4:27 pm
by joe jeep
Thunderpole sell an ERF Mirror mount kit which has the upside down aerial. It's under Mirror Mounts, second from the bottom, looks good. Would that mean i could attach it to a fibreglass scrimm net pole stabbed in the ground.
Posted: Thu Jun 09, 2011 5:17 pm
by ellitanthalas
TP also used to do an EGP (Electronic Ground Plane) mount, which I found worked amazingly on the bike. Still using it, in fact!
Posted: Thu Jun 09, 2011 5:26 pm
by joe jeep
ellitanthalas wrote:TP also used to do an EGP (Electronic Ground Plane) mount, which I found worked amazingly on the bike. Still using it, in fact!
Where would i find one of those????
I would just like to say thanks to all of you who have or will undoubtedly help me!!!
=D> =D> =D> =D>
Posted: Fri Jun 10, 2011 11:54 am
by ellitanthalas
Thunderpole used to do them, which is where I got mine. Dunno why they stopped as these things are great.
Closest TP have is the aforementioned ERF kit, which does the same thing but has that lower antenna creating what I believe is effectively a dipole. Just be careful of the lower part.
And I *believe* you can indeed whack that onto your scrim pole... but why is it made of fibreglass? Is that authentic WW2 period kit, then? :lol:
Posted: Fri Jun 10, 2011 11:57 am
by joe jeep
No, i don't believe it is WW2 but slightly later, but it's green ex-MoD and blend in it's surrounding, perfect for aerial mounts!! :D
