Eurosonic 80 channel handheld cb
Posted: Mon Jun 06, 2011 8:17 pm
by Rossyy7
Hi I'm Ross , could anyone help me I need a new battery pack for me eurosonic 80 channel, where could I get one , thanks
Re: Eurosonic 80 channel handheld cb
Posted: Thu Jun 09, 2011 8:15 pm
by Guzzy
I think the Midland 42 accessories will fit, but double check first. Give Thunderpole a quick call before ordering.
http://www.thunderpole.co.uk/midland-42-essentials.html
Posted: Tue Oct 11, 2011 4:24 pm
by radiomaker
Rossyy7: What did you do about a battery pack?
Did you get the Maycom NP126-C battery pack for their Model AH27?
I was just wondering whether you had any issues with the battery contacts not meeting those in the radio itself. I know you can fix that with conductive paint.
Was your's a tight fit as well?
I have the same radio & I have ordered the same battery pack. There's no way I can get the full 4W RF o/p without the battery pack. I have also bought a extra-long rubber duck.
Getting ready for the Big Net.......
Posted: Fri Oct 14, 2011 10:53 pm
by radiomaker
If you get the Maycom NP126 battery pack you will need to do two things with it to make it fit your Eurosonic Ultimate. I used a tiny file to remove a very small amount of plastic from the open end of the fitting grooves. This is so the battery pack will lock into position.
Then you will need some conductive paint to extend the area of the battery contacts.
Some ebay sellers have the stuff. It contains silver & it is ferociously expensive, but as I needed it I paid up.
Now, I need a photocopy of the manual from another owner of a Eurosonic Ultimate.
I need to know if there is any indication on the LCD display of the RF power the set will put out on 'Transmit'?
As the battery pack discharges so the radiated power drops as well. As the erp drops below 4W I would need to give the battery a short charge.
